outlet leak on new water heater
Discussion in 'Water Heater Forum, Tanks' started by sproksch, Apr 17, 2011.
  1. sproksch
    sproksch New Member
    Apr 21, 2010
    Virginia
    hello,
    Just installed a new ordinary electric water heater yesterday. Everything seems to work ok, except I have a very small droplet of water that forms at the base of the outlet heat trap (photo attached). What could be the problem? How should I diagnose it?
    This is my first water heater install - I read up alot and I feel like I did everything by the book: I bought a pair of heat traps, spread pipe joint compound over the threads and installed them into the water heater. I created the connector by sweating a female threaded connector to my copper pipe, then installed it onto the heat trap. I cranked it down pretty well - is it possible to over-tighten these connections? Did I miss something in the install?
    Any advice would be appreciated - I would like to know what to do to diagnose before cutting into my pipe. I feel like some plumber's putty could do the trick, but if I messed up something on the install, I suppose better to figure it out now.
    Thanks much!
    Steve
  2. dlarrivee
    dlarrivee New Member
    Jun 28, 2009
    Foam/Fireproofing/Acoustical
    Canada
    You're going to have to cut the riser and use a coupling... clean the threads and crank it down a tiny bit more so long as the threads aren't damaged at all.
  4. sproksch
    sproksch New Member
    Apr 21, 2010
    Virginia
    Thanks - I'll give it a try! I thought I cranked it down pretty hard, but I'll try again.
    Steve
  5. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    FWIW, Plumber's Putty is a clay like product that is used to set sink drains. The product that is used on pipe threads is Pipe Dope. This is a gooey substance that is just brushed over the threads. I prefer this to Teflon tape, although some folks prefer the tape and some use dope over the tape. Dope can be a bit messy, tape is neat, but sometimes a bit tricky to wrap. Comes down to personal preference.
  6. sproksch
    sproksch New Member
    Apr 21, 2010
    Virginia
    Thanks much! I originally used pipe dope on the threads and after I looked, each connection had a tiny droplet of water that would form. I just finished re-doing everything, this time with the teflon tape, and that seems to have done the trick! I'm not sure where I got the idea to use pipe dope - my plumbing book says to use Teflon tape for water heater fittings. Whatever the case, problem solved!
  7. Terry
    Aug 17, 2004
    You can use either or both.
    Both is always a safe bet.
    I'm glad it's fixed now. Cool.
    Edited after Gary's post. Either meaning pipe dope or Teflon tape.
    No plumbers putty. I forgot that Gary mentioned not to use putty, and he's right. No putty.
  8. Gary Swart
    Sep 1, 2004
    Yakima WA
    My point was that there is a difference in plumbers putty you were thinking of using in your original post, and pipe dope. I doubt if the original leak was due to using pipe dope, most likely you just didn't tighten enough. Glad the problem is fixed.
  9. hj
    I ALWAYS use pipe dope, and NEVER use Teflon tape, so your leaks were NOT caused by the type of sealant you used. You either did not apply it properly, or did not tighten the nipples adequately. As a side note, I also never use those "dielectric" nipples unless they come with the heater, since I would NEVER spend the money to buy them. They are "cosmetic" so buying them is wasting your money.
  10. jimbo
    jimbo Plumber
    San Diego, CA
    3/4" pipe fittings require a pretty good amount of torque....if you were using a small wrench, it may just not have been tight enough. This is not an exact science, but looking at the number of threads exposed, I might have opined you need one more turn.
  11. ballvalve
    Dec 28, 2009
    northfork, california
    Flex lines would have made your repair much easier, and the romex would like to be in flex also....
  12. Gary Swart
    Sep 1, 2004
    Yakima WA
    Ballvalve makes an excellent point. Some places require the flex connectors, other prohibit them...go figure. But, they sure do make connecting the water lines easy. My gas heater doesn't use much Romex, but a flex line would likely be good to use also.
Similar Threads: outlet leak
Water Heater Forum, Tanks SuperStor Indirect leak at hot water outlet Nov 3, 2012
Water Heater Forum, Tanks Humidifier connection to hot water outlet Yesterday at 8:19 AM
Water Heater Forum, Tanks Anode rod under hot outlet? Ao Smith GVR 50 300 Nov 1, 2016
Water Heater Forum, Tanks HELP: Can't get 1" stainless flex connectors to seal to inlet/outlet nipples Dec 31, 2015
Water Heater Forum, Tanks What's better than a Bradford White dual outlet (radiant and domestic) gas heater? Jun 13, 2014
