Outlet inside peninsula cabinet
Discussion in 'Electrical Forum discussion & Blog' started by JMingrone, Dec 12, 2012.
  1. JMingrone
    JMingrone New Member
    Aug 21, 2006
    I'd like to put a utility outlet on the end of a peninsula. The cabinet is a slide out trash container and there's enough clearance inside for a shallow outlet box, so no problem there. What i'm not sure is how you run the cable to the box. Plain old Romex? Wire mold? Other? The feed comes up through the floor from the basement.
    Thanks,
    Jay
  2. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Plain old romex if nothing is going to beat it up when the trash container is used. The feed is supposed to come off of the GFCI protected kitchen counter top circuit.
  4. JMingrone
    Aug 21, 2006
    Thanks Dave. And for the reminder about the GFI.
  5. hj
    quote; The feed is supposed to come off of the GFCI protected kitchen counter top circuit
    And why can't it have its own feed and GFCI receptacle?
  6. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    It can. But it will not fit in a shallow box.
  7. big2bird
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    I would use M/C 90 to feed this, and find a way to get a deeper box in there. Perhaps a 52OW, and have it stick inside the cabinet. We do that for school labs all the time.
  8. jadnashua
    You can always use a GFCI breaker rather than trying to use a GFCI recepticle if depth is an issue. It's just that resetting it may be more of an annoyance but the thing should not trip it, and if it's dedicated, it normally won't be an issue.
  9. JMingrone
    Aug 21, 2006
    Well, after all the careful planning, I feel really foolish about not having run a branch off either of my 2 GFI countertop circuits, which would have been simple before the walls were up!
    Jim- good idea about a GFI BREAKER as a work-around.
    Jay
  10. ActionDave
    Feb 4, 2009
    Electrician
    Colorado
    You can do that too.
  11. hj
    quote; Jim- good idea about a GFI BREAKER as a work-around.
    I assume your circuit breaker panel is in the basement. Here it would be outdoors, and would not be "fun" to have to go outside to reset it, especially if it was raining like it was last evening.
Similar Threads: Outlet inside
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
Electrical Forum discussion & Blog Creating a new earth connection for grounding an outlet Feb 19, 2017
Electrical Forum discussion & Blog New Outlets= Erratic Dimming Power Jan 10, 2017
Electrical Forum discussion & Blog What Monkey Wired this outlet?? Jan 10, 2017
Electrical Forum discussion & Blog Convert outlet to hardwire Nov 16, 2016
