Outlet ground prong orientation
Discussion in 'Electrical Forum discussion & Blog' started by apparentgenius, Nov 24, 2008.
  1. apparentgenius
    apparentgenius New Member
    May 5, 2008
    Oregon
    Ok, so here's an easy question.
    I'm installing the outlets in my new house. I know that the code does not specify the orientation of the ground slot (up or down), however, Ray Mullen's residential wiring guide suggests the ground in the up position is superior. His reasoning is that if you have a metal cover plate and it comes loose, kit will hit the ground and not a hot prong. Yet, every house I look at has the outlets installed with the ground slot on the bottom.
    Opinions?
    Glen
  2. Billy_Bob
    Billy_Bob In the Trades
    Apr 2, 2008
    Ground down. Many appliance cords are designed so the cord will go down when plugged in to an outlet with the ground prong on the bottom.
  4. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    Didn't know that outlets had ground slots
  5. jimbo
    jimbo Plumber
    Only a tiny percentage of cover plates found in residential are metal, and when was the last time you say the screw fall out of a cover plate? Mostly this is a solution in search of a problem. If the NEC dudes could find any reasonable data to support it, they would have made it a code a long time ago!
  6. jar546
    jar546 In the Trades
    Feb 20, 2008
    USA
    His method is good practice so if you ever replace a cover with a metal one then you are covered. This way you are consistent with your installations. I do it that way except:
    I always look at the appliance cord to see how it is oriented. Refridge cords are usually with the equipment grounding conductor prong in the down position.
    Your call completely, either way you are code compliant.
    My reasoning for placing most of them grounding side up is that the homeowner may change the cover in the future and if they do place a metal cover on then I feel I did a safer install just in case.
  7. hj
    ground
    In hospitals and health care facilities the ground terminal is on tbe top so that if ANY metal object is dropped and gets between the plug and receptacle it will short out and trip the breaker, not shock a patient who might be on the other end of the metal object.
  8. apparentgenius
    May 5, 2008
    Oregon
    Ok, ground hole, ground pin acceptor, ground port, place meant for ground prong etc. if you don't want to call it a slot. If you knew what I meant, what's the point in posting to be difficult?
  9. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Listen you all we need to first let Glen know that outlets don’t have ground slots but receptacles do.
    Come now you all if you going to do something do it right or not at all.
  10. apparentgenius
    May 5, 2008
    Oregon
    Jar 546,
    Thanks for the help. I think I'm going to go with ground up unless there is a fixed item, like a fridge where it works better in the down position. I read another story about how a kid got shocked using a remote control toy with an antenna that slid down the wall and hit the hot lead.
    GLen
  11. apparentgenius
    May 5, 2008
    Oregon
    Thanks for the clarity. I full agree with doing it right, that's why I ask questions and pass inspections on my first try. Thanks again for the help
    From Wikipedia
    Power sockets, power receptacles, or power outlets are female electrical connectors that have slots or holes which accept the pins or blades of power plugs inserted into them and deliver electricity to the plugs. Sockets are usually designed to reject any plug which is not built to the same electrical standard. Some sockets have a pin that connects to a hole on the plug, for a ground contact.
  12. Chris75
    Chris75 Electrician
    Aug 12, 2007
    Electrician
    Litchfield, CT
    This thread is ridiculous, it can be argued till the cows come home and even then it wont be settled. :D Install them whatever way you think looks right to you.
  13. apparentgenius
    May 5, 2008
    Oregon
    SInce there is no clear right or wrong, I'm going to buck the trend with what I see around here and go ground prong up because I like the idea of the ground being up incase something drops on it.
    Glen
  14. jimbo
    jimbo Plumber
    By apparentgenius:
    "" Quote:
    Ok, ground hole, ground pin acceptor, ground port, place meant for ground prong etc. if you don't want to call it a slot. If you knew what I meant, what's the point in posting to be difficult? ""
  15. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    This is why I won't even comment on the topic. It is ridiculous!
  16. Speedy Petey
    Jun 16, 2007
    NY State, USA
    I make this typo ALL the time. Luckily for me FF catches it.
  17. Cass
    Cass Plumber
    Nov 12, 2005
    The absolute safest way to install outlets would be at a 45 degree angle with the hot on the bottom so something droping would be protected from touching the hot by not 1 but 2, the ground prong and the neutral prong...2 prongs will hold more weight and just in case 1 of the prongs broke and failed the other would be there as a back up....
    why hasn't any one mentioned this...
    You guys just don't think outside the box enough...
    :D
  18. jwelectric
    Jun 14, 2007
    Instructor
    North Carolina
    Uh OH here is another one of them Wiki gotta be right experts.
    Thare ani't nothing that Wiki has to say that changes the words in the only reference that counts, the NEC.
    You can have a Lighting OUTLET. Which way do you turn the ground slot in this outlet?
  19. Billy_Bob
    Apr 2, 2008
  20. jar546
    Feb 20, 2008
    USA
    Glad you are using your head. There is another reason beyond the metal plate, especially with all of the remote control toys.
  21. apparentgenius
    May 5, 2008
    Oregon
    I install them upside down when I use them for shop lights.
    Glen
Similar Threads: Outlet ground
Electrical Forum discussion & Blog Creating a new earth connection for grounding an outlet Yesterday at 5:01 AM
Electrical Forum discussion & Blog Home PC, ungrounded outlet and CFCI Apr 2, 2015
Electrical Forum discussion & Blog Do GFCI Outlets Need a Ground? Nov 14, 2014
Electrical Forum discussion & Blog Using grounding bar inside 3-gang metal outlet box Mar 14, 2014
Electrical Forum discussion & Blog Connecting Neutral and Ground at Power Outlets Oct 31, 2010
