Outdoor Water Supply from Lake
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Dave1985, Sep 4, 2011.
  1. Dave1985
    Dave1985 New Member
    Sep 4, 2011
    Queens, NY
    So I'm looking at buying a house in New Hampshire where the winters get cold. They use water that comes from the lake which is about 30-40 feet away.
    they had a buried water line that is crushed and they replaced it with another water line that is on the surface, so obviously it freezes in the winter.
    Assuming I can not fix the underground pipe and assuming I do not have enough land to drill a well, what are my options for the pipe above ground?
    Insulate it? Use heat tape? Both? and then bury it a little under the ground?
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    Insulate it. As long as it get regular (frequent) use, it should not freeze. For less frequent use some people put in a drain-back system.
    http://www.cottagewatersupply.com/
  4. jimbo
    jimbo Plumber
    In souther NH the freeze line is probably about 42" deep! Insulation does little to keep a pipe from freezing. You could use heat tape, which is an expensive solution. Is this a year round occupancy? If not, figure out how to winterize. If it is year-round, get the pipe installed at the proper depth.
  5. hj
    The bigger question is whether the "lake water is really potable water", unless you only use it for utility purposes.
Similar Threads: Outdoor Water
Plumbing Forum, Professional & DIY Advice Water Pressure on a Outdoor Hose / Length vs. ID Nov 20, 2016
Plumbing Forum, Professional & DIY Advice Water Service line to house/outdoor faucet branch... needs a look. Jul 2, 2015
Plumbing Forum, Professional & DIY Advice Low water flow in anti frost outdoor faucet Apr 19, 2015
Plumbing Forum, Professional & DIY Advice New homeowner outdoor water faucet problem. May 25, 2014
Plumbing Forum, Professional & DIY Advice Water line for outdoor kitchen Mar 24, 2014
