I'm in the planning stages of moving my pressure tank to a different location in my house, along with the pressure switch. They're currently in the under-porch room that I'm turning into a wine cellar, and that room lacks a drain. So in order to free up room and prevent damage in the event of a leak, I'm moving the tank/switch to my furnace room (with a drain), next to the softener. The distance from old to new location is probably 40' by way of the pipes.
I'm debating with myself about the outdoor branch (hard water) that comes off the line about 1/3 of the way from the tank to the softener. This is the branch that feeds my lawn sprinkler system. The main line is 1" and the outdoor branch is also 1". When my sprinklers are on, the pump runs constantly, as it should, rather than switching on/off repeatedly.
Does it matter if this outdoor branch is upstream of the pressure tank & switch? or should I move it so it's still downstream of the pressure tank like it is today?
In other words:
Current Setup:
Inlet-Tank-----------Tee-----------------------------------Softener
Proposed:
Inlet------------------Tee------------------------------------Tank-Softener
or
Inlet-----------------------------------------------------------Tank-Tee-Softener
3/4 hp, 10 gpm pump if that makes a difference.
Dave
In other words:
Current Setup:
Proposed:
or
Dave
