outdoor soffit lighting
Discussion in 'Electrical Forum discussion & Blog' started by picapiedra, Sep 29, 2010.
  1. picapiedra
    picapiedra New Member
    Jun 20, 2009
    I have bough from H.D. a Commercial Electric Outdoor Soffit Lighting, retrofit kit 6 pack. 4 inches outdoor soffit kit. C2 545898.
    The problem that i have is:
    the remodel CLIP is too short to hold the housing can against the soffit. I believe that the clips will do OK in a ceiling with drywall..BUT...my soffit is 1/8 inch and the pots seems very loose.
    Is any way to have a "longer" clips that will hold the housing cans or any other way to have this installation more rigid?
    I live in Canada..i am concern about a strong wind could rip the pot lights.
  2. drick
    drick In the Trades
    May 16, 2008
    Unfortunately you bought this as a kit. Otherwise I'd just tell you to return the remodel cans, pull out the soffit, and install new construction cans which would really be the best way to go.
    Alternately drill four small holes thru the can just a hair above where the soffit will be. Install the can and then install four screws thru the holes you just drilled that will extend an inch or so over the soffit to hold the can in place. Essentially you are trying to pinch the soffit between the lip of the can and the screw.
    Oh and bees seem to love building nests inside cans in a soffit so you are using an open trim watch you fingers when relamping in the summer.
    -rick
  4. Speedy Petey
    Speedy Petey Licensed Electrical Contractor
    Jun 16, 2007
    NY State, USA
    OK, I have to ask:
    Seriously? You think ripping out the soffit and installing new work cans would be "best"?
    My advice is to return the CE junk and get Halo or another quality name brand. I know for fact that Halo H99RT cans will work fine in your situation Pedrito.
  5. hj
    qquote; Otherwise I'd just tell you to return the remodel cans, pull out the soffit, and install new construction cans which would really be the best way to go.
    "The best way to go"? That is like saying that if you cannot find the tires you like, just scrap the car and buy a new one.
  6. picapiedra
    Jun 20, 2009
    I strongly believe that H.D. as the manufacture those pot lights, they should have a longer clips so that it can stay firmly. As stated in their box..it suppose to be an outdoor SOFFIT lighting.
    What i have found in other forums....electric contractors placed a 1/4 inch of plywood of dimensions of 2 by 2 inches on top of the soffit and glued....AND THAT WILL HOLD the pot lights UP and FIRM.
    Thanks for your input.
Similar Threads: outdoor soffit
Electrical Forum discussion & Blog Hot tub wiring (outdoor junction box) Sep 1, 2016
Electrical Forum discussion & Blog Outdoor Outlets - Want The Best! Sep 3, 2015
Electrical Forum discussion & Blog how to test an outdoor CF light before hanging in up Aug 6, 2015
Electrical Forum discussion & Blog Mounting outdoor outlet help needed - preference between two examples shown Aug 31, 2014
Electrical Forum discussion & Blog Transition from in-wall to outdoor EMT conduit options? Jun 19, 2014
