Outdoor Shower Diverter
Discussion in 'Shower & Bathtub Forum & Blog' started by marshdale, Jan 9, 2014.
  1. marshdale
    marshdale New Member
    Jan 9, 2014
    Knoxville
    The diverter to our outdoor shower cracked due to frozen water this week.
    Can someone tell me the make of this particular one so I can buy a replacement?
    Thanks, JB
  2. Terry
    Aug 17, 2004
    Yes.
    You left it with water in it.
    Not much you can do buy keep those drained down over the Winter. You can install a four port single handle valve, with a diverter spout on the bottom. That would drain the riser. But the pipes going to the valve can and will split too.
  4. Reach4
    Reach4 Well-Known Member
    Sep 25, 2013
    Idea...
    That is a low-pressure area. Suppose you opened the plug, and let things dry. Put some JB-weld on the tip of a finger in a nitrile glove. Shove stuff into the crack from inside. If you are brave enough, you could suck on the outside of the crack to draw the JB-weld inside better.
    I hope you can keep the threads clean. Then you can put the plug back in with teflon tape, and let the water out at the end of the summer next time.
    An alternative idea is to apply a suction from one of the pipes with a vacuum cleaner. Apply JBW to the outside, and let it be drawn it. At some point, turn off the suction and goop some extra JBW.
    If that is steel, you could find somebody to braze or weld a repair.
    Of course if you can find a replacement, that will be more straight-forward.
  5. marshdale
    Jan 9, 2014
    Knoxville
    When I go back with new diverter, I'll install a pipe from bottom of diverter with a hose bib on the end. That way it can be used to wash feet off during the season, and fully drain diverter in the winter (there are isolation valves for the outside shower inside a conditioned space).
    Any idea of the manufacturer for this particular diverter? It was only installed about 2 years ago, and I was hoping to go back with exact replacement for ease of installation.
  6. johnfrwhipple
    johnfrwhipple BATHROOM DESIGN & BUILD for both Canada & the US
    Jul 20, 2009
    Design Work World Wide: Bathrooms Vancouver Area
    North Vancouver, BC
    Why not install a proper hose bib outside with the frost free design - but pipe it with hot and cold so you can have warm water when you use it. That should work fine with no fear of freezing....
  7. marshdale
    Jan 9, 2014
    Knoxville
    Diverter Manufacturer
    Thanks for all the helpful tips, but what I could really use now is the manufacturer of this specific diverter. Cheers!
  8. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
  9. marshdale
    Jan 9, 2014
    Knoxville
    I searched for hours, but never could find that exact model.
    Thank you very much!
Similar Threads: Outdoor Shower
Shower & Bathtub Forum & Blog Leaking outdoor shower May 7, 2015
Shower & Bathtub Forum & Blog outdoor shower May 28, 2005
Shower & Bathtub Forum & Blog Adding a step to an outdoor pool jacuzzi Jul 26, 2014
Shower & Bathtub Forum & Blog Disconnecting outdoor plumbing? Jan 11, 2010
Shower & Bathtub Forum & Blog Outdoor Spa Questions Jun 9, 2006
