Outdoor plumbing in New England
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by sebrulotte, Jun 14, 2009.
  1. sebrulotte
    sebrulotte New Member
    Jun 14, 2009
    Hi,
    I live in NH and I'm looking to install an outdoor faucet away form my house. We are putting in a large veggie garden and would like to have a outdoor faucet next to the garden so we are not haivng hoses across out existing lawns . It would also require about 200 ft of hoses. We have a well which is at the same level as the garden area but approximately 100 feet away.
    Can I run pipe directly from the well (under ground) to the garden area and if so how deep would it need to be so I wouldn't have to drain it on a yearly basis. Or is that not possible?
    Thanks for your advise and knowledge.
    Liz
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    You would need to bury it at least 48" and install a yard hydrant.
    [​IMG]
  4. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    There are a couple of ways to handle this. You can bury the pipe below frost level in your area which is probably 48" in New England, and use a hydrant that shuts off 48" below the surface and will drain the water from the faucet and vertical pipe down to the lower pipe. A second way to protect from freezing is to drain the line each fall. The problem with that is if there are any dips in the line, water will not drain from the dip. If you have an air compressor, then you can blow the water out with the compressor. Hoses should be drained and put away in the fall.
    [​IMG]
    They make yard hydrants that are self draining for winter use.
    This is what I use.
  5. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    Dido on the advice but to be clear, you must run the line from inside your home after the pressure tank.
  6. Cass
    Cass Plumber
    Nov 12, 2005
    Why is that...there should only be a footer valve or check valve at the pump and the rest of the system will pump up to pressure and work fine...idealy yes...and there should not be a shutoff valve between the pressure switch and pump...that could cause big problems...
  7. sebrulotte
    Jun 14, 2009
    Outdoor plumbing in NH
    thank you all for your advise. I will share this with my husband.
  8. 99k
    Aug 16, 2008
    Two issues. First, in CT the check valve is at the cross just before the pressure tank so if they have that set-up it just won't work. Second, I think I'd rather use extra poly pipe and make the connection in the house instead of trying to find the pipe going to the house from the well and then making a splice that is buried.
Similar Threads: Outdoor plumbing
Plumbing Forum, Professional & DIY Advice When indoor plumbing goes outdoors.... to sewer. What pipe type?? Mar 13, 2014
Plumbing Forum, Professional & DIY Advice Please help me with outdoor plumbing. Aug 5, 2013
Plumbing Forum, Professional & DIY Advice Bringing plumbing to an outdoor shed? Apr 8, 2011
Plumbing Forum, Professional & DIY Advice Plumbing for Outdoor Kitchen Mar 4, 2009
Plumbing Forum, Professional & DIY Advice Plumbing exposed to extreme outdoor temps Aug 19, 2007
