Outdoor Conduit Conductors
Discussion in 'Electrical Forum discussion & Blog' started by iminaquagmire, Feb 18, 2009.
  1. iminaquagmire
    iminaquagmire DIY Senior Member
    Dec 16, 2007
    FF/EMT
    I'm fixing to do a panel swap (will be permitted and inspected to 2005 NEC with 2008 provisions, i.e. AFCI) from an old Federal Pacific fuse panel to a Square D breaker box. House is currently BX and some MC from new installs. NM is not allowed per city ordinance.
    The reason for the swap is the previous homeowner's handywork and simple age. The panel is a mess and the disconnect for the AC is wired directly to the service entrance lugs. I'd like to do the new run to the AC condenser with THWN in schedule 80 PVC. However, I've also seen XHHN mentioned for use. Is one more appropriate than the other?
  2. codeone
    codeone Code Enforcement
    Sep 5, 2008
    Code Enforcement, Instructor
    North Carolina
    Do you mean XHHW instead of XHHN?
    The THWN has a thinner jacket is for wet locations which the 2008 clarifies inside pipe outside as a wet location.
    Dont see a XHHN listing in the NEC
    There is a listing for XHHW which is also listed for wet locations however the outer jacket is thicker than THWN.
    THWN is most likely easier to pull and handle both good conductors for your purpose.
  4. iminaquagmire
    Dec 16, 2007
    FF/EMT
    That's what I meant. Will use THWN pending approval of plan. Thanks.
Similar Threads: Outdoor Conduit
Electrical Forum discussion & Blog Transition from in-wall to outdoor EMT conduit options? Jun 19, 2014
Electrical Forum discussion & Blog Outdoor Outlets - Want The Best! Sep 3, 2015
Electrical Forum discussion & Blog how to test an outdoor CF light before hanging in up Aug 6, 2015
Electrical Forum discussion & Blog Mounting outdoor outlet help needed - preference between two examples shown Aug 31, 2014
Electrical Forum discussion & Blog How to wire outdoor electrical outlet using old hot tub connection? Jun 3, 2014
