Organic trap?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by hotrodjohn, Apr 7, 2009.
  1. hotrodjohn
    hotrodjohn New Member
    Apr 7, 2009
    I know this is a tough question. I am setting up a hydrogen peroxide injection system for my private well system along with a carbon whole house filter. The water treatment guy that wanted a bunch of money to do this said he recomended an "organic trap" which is basically a water softener with the proper media inside (resin) that gets recharged or backwashed with a brine (salt) solution. He did not tell me what media he would use ,said it was propriatary but he called it an organic trap. I know there is sulpher in the water which is what the peroxide is good at fixing and I know there is some iron but not much and I think that at times during the year there might be tannins present in the water. I have not had much luck at getting a affordable water test to figure this all out and I am wondering about the organic trap media? anyone know anything about this from what I have posted?
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    You need a professional water test!! Imagine calling the doctor over the phone and asking for a prescription without a visit. You are wasting your time and money otherwise without the data.
  4. hotrodjohn
    Apr 7, 2009
    ok
    I agree, anwhere you can recomend?
  5. Gary Slusser
    Retired
    Any water treatment dealer or lab or your county extension office can do the tests; or you can buy a kit and do them yourself. You do not need a certified lab.
    He probably meant a sodium form anion resin used for tannin removal but, if your have iron and H2S you need a correctly sized retention tank and turbidity filter before this "organic" piece or a softener.
    He may be mixing a couple resins in it and doesn't want to tell you what it was because then you'd want to know which ones. And tannin removal can be difficult and he may have found something that works well in your area but IIRC usually tannins don't come and go. Turbidity can.
    Get your test results and post them.
  6. 99k
    Aug 16, 2008
    I highly recommend you use a certified lab ... remember you are needing to spend a lot of money for this equipment so trying to save $50-100 would not be wise:rolleyes:
Similar Threads: Organic trap
Pumps and Tanks Well Forum & Blog. Water is life. Strapping inside clay sump pump Nov 24, 2015
Pumps and Tanks Well Forum & Blog. Water is life. Can wrong check valve placement or air trapped by fittings cause cavitation? Jul 1, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Proper Sediment Filter/trapper positioning Jan 5, 2012
Pumps and Tanks Well Forum & Blog. Water is life. Location of Sand Trap? Apr 22, 2011
Pumps and Tanks Well Forum & Blog. Water is life. Info needed on Sand Trap Manufactures/Distributors Dec 13, 2010
