Order of the gaskets
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Hans L, Jul 4, 2013.
  1. Hans L
    Hans L New Member
    Boy, do I need help here.
    I have a Pfister Pfirst Series Centerset Bath Faucet, 4 Inch, 2-Handle, 3 Hole Lavatory Faucets Professional Grade, probably Model #: G143-5100 (if not exactly, my model it probably works exactly the same way), in one bathroom. It leaked for the first time a few days ago, and I demounted it to clean it. Now, I do not remember the order of the three gaskets.
    Details: In the valve (960-802 Cartridge), there are two butterfly-like hard plastic "gaskets" (H) and one butterfly-like soft rubber gasket (S). I suspect that the order should be HSH, but I am not sure. Is there an expert here that would know?
    Thank you very much for your possible help!
    Hans L
  2. johnjh2o1
    johnjh2o1 Plumbing Contractor for 49 years
    Aug 9, 2009
    Retired
    Florida
  4. hj
    They are NOT plastic, they are ceramic, and if you removed them it is not always easy to get they reassembled properly. The two ceramic pieces fit together, and very specific order, and the rubber goes on the outside to hold them in place when it is tightened into the faucet.
Similar Threads: Order gaskets
Plumbing Forum, Professional & DIY Advice How do I Extend Existing Waste Pipe In Order to Attach Toilet Flange Mar 4, 2017
Plumbing Forum, Professional & DIY Advice Feedback on DWV Diagram and order of fixtures Sep 27, 2015
Plumbing Forum, Professional & DIY Advice Kraus Strainer Assembly Order? Jun 19, 2012
Plumbing Forum, Professional & DIY Advice Water Well Line - Sediment Filter - Expansion Tank - Water Softener - H2O Htr. Order? Apr 6, 2011
Plumbing Forum, Professional & DIY Advice Special Order Hose Bibbs Aug 22, 2008
