decarguy
Reporter
Hi, I've been perusing these many great threads and need some advice.
We have a 36 year old house with 1.5" drain pipe to a standalone laundry area. This was probably code at the time. We have a brand new LG high capacity washer and have had no problems to date. I know this is a 1.5" drain because I tore out the drywall with the idea of moving the washer and adding a laundry sink. My understanding is that the 1.5" drain is not even up to current code for a washer let alone adding a laundry sink to the drain line. Unfortunately, the drain runs under a cement slab making any attempt to upgrade to 2" pipe difficult. Below are my known options. I would like input on each of these options and any others that I may not have thought of. Thanks in advance.
1. Tear up the cement floor and replace the 1.5" with 2" drain. This would be a very last straw.
2. Add the laundry sink (with proper connections and venting) and just avoid using it while the washer is draining (this is not likely to be a big problem). This is probably what my wife would like. Since our current high capacity washer does not seem to have any problems, we could probably get away with this. I know this does not meet current code but if they had put in a laundry sink back in the day we would probably be sailing along without problems and everything would be "legal". I know that whenever you change any plumbing you should bring it up to current code so I am reluctant to do this, but...
3. Remove the washer box drain and connect the laundry sink and then drain the washer into the sink. I suppose the laundry sink gives me some "overflow capacity" that would help guard against someday exceeding the capacity of the 1.5" drain pipe (i.e. it gets partially clogged). My wife does not particularly like this idea. And, I can see where there could be a problem if the sink drain got plugged with something accidentally (sounds like something I would do). I think it would be in compliance with current code.
4. Forget about the sink and live with the 1.5 until they create washers that exceed this older plumbing.
Thanks again.
Thanks again.
