Options for a high set P-trap
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by seattlesink, Apr 17, 2014.
  1. seattlesink
    seattlesink New Member
    Apr 17, 2014
    Seattle, Washington
    Hi folks, I would really appreciate some advice on where to go from here.
    My situation:
    I have recently been redoing many parts of my kitchen, and the cabinets and countertops are all still unattached. We got a new sink that is deeper. I was able to get the fittings to work for a P-trap to go into the current drain pipe (cast iron in the wall, behind lathe and plaster). However, we have also purchased a dishwasher which changes the drain situation again. The dishwasher will be placed across the path from the sink (on the opposite wall, only about 4-5 feet away).
    The plan is to run an extended (maybe 12ft) drain hose from the dishwasher, under the floor (easily accessible), back up through the back wall, and into the sink drain system. I don't foresee a problem with the 12ft extension, but the main problem I'm faced with is how to get the dishwasher drain hose before the P-trap. The piece that attaches to the sink is very close to the actual P-trap, so it doesn't seem like there is space to add one of those Y-pieces for the drain hose.
    Suggestions? I don't know my way around the plumbing options here very well, so any help is greatly appreciated.
    Kind regards,
    Matt
  2. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Lower the fitting in the wall so that the trap will be low enough to accommodate a dishwasher tailpiece. For a deep sink the fitting in the wall should be 15-17" above the floor. This would also allow you to install a disposer in the future.
  4. hj
    Change to a brass sink drain. It should be short enough that the "proper" dishwasher drain fitting will work.
  5. seattlesink
    Apr 17, 2014
    Seattle, Washington
    Hi hj,
    Do you mean something like this?
  6. hj
    Yes, and you will also need a "captive nut dishwasher tailpiece" so you do not need a short piece between the tee and drain which would lower it again.
  7. seattlesink
    Apr 17, 2014
    Seattle, Washington
    Thanks AJ and cacher_chick for the help. I'm going to give it a shot this weekend and see what happens.
    Have a great weekend all!
Similar Threads: Options high
Plumbing Forum, Professional & DIY Advice New 10" deep sink - now waste drain too high! options? May 18, 2010
Plumbing Forum, Professional & DIY Advice Options for extra long dishwasher supply Mar 17, 2017
Plumbing Forum, Professional & DIY Advice Broke my cold water stem for my shower. Options? Feb 14, 2017
Plumbing Forum, Professional & DIY Advice Island Sink / Venting Options Jan 28, 2017
Plumbing Forum, Professional & DIY Advice Superior pump vs Zoeller; Zoeller options Jan 19, 2017
