Open Toto Power Gravity Fill Valve
Discussion in 'Toilet Forum discussions' started by mj-victoria, Aug 27, 2008.
  1. mj-victoria
    mj-victoria New Member
    Aug 27, 2008
    Hi,
    My fill valve periodically chirps and refills the overflow tube. This happens particularly when another faucett is opened. The flapper has a good seal.
    Is there an easy way to open the top of the fill valve and see if it just needs cleaning?
    Thanks
    MJ
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Yes the top unsnaps and lifts off. You can flush it out and clean it. The parts are also replacable.
  4. Peanut9199
    Peanut9199 Customer Service Manager Plumbing Wholesale
    Apr 23, 2007
    Ontario, Canada
    Actually it depends on which fill valve you have if it is the one that has "Power Gravity" molded into the blue cap the yes you can but if it is the the one that has a white adjustment screw on the top then no you cannot.
    Sorry can't find the picture that has both of them on it.
    Maybe Terry can add on to this.
  5. Redwood
    Dec 15, 2007
    Service Plumber
    If it's chirping its the older style valve.
  6. mj-victoria
    Aug 27, 2008
    Thank you
    Many thanks for the posts.
    The version I have is the blue molded one without a screw top.
    I was just a bit concerned that pulling wrongly on the top will break it.
    MJ
  7. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    Yes the one with the screw top does not come apart you need to replace the whole fill valve.
  8. Redwood
    Dec 15, 2007
    Service Plumber
    But then the poster does not have the screw top fill valve...:cool:
  9. Peanut9199
    Apr 23, 2007
    Ontario, Canada
    Yes i didn't read it propery.
    I seen with instead of without a screw top.
    opps
Similar Threads: Open Toto
Toilet Forum discussions Toto Ultramax Valve Sticks Open Sep 25, 2009
Toilet Forum discussions How to open top cover of Toto Dual flush? Sep 9, 2009
Toilet Forum discussions Any Toto model with bigger seat openings? May 31, 2009
Toilet Forum discussions Suggestions on cleaning toilet siphon jet opening Mar 6, 2014
Toilet Forum discussions Flange opening minimums Jun 29, 2011
