One thermostat for room with two zones
Discussion in 'HVAC Heating & Cooling' started by jr_spyder, Nov 2, 2009.
  1. jr_spyder
    jr_spyder New Member
    Nov 2, 2009
    MA
    I've been renovating my 150 house that on the coldest days never had a warm kitchen. I now have radiant heat in the floor in the kitchen on it's own zone and that should take care of me most days. The heat loss analysis says this won't be enough heat on some days so I also have a radiator in the same room also on it's own unique zone. Now the challenge is controlling them. One way would be to use two thermostats but I'd rather not have too much electronics on the wall in the old house. If I had two I could set the floor to 68 and the radiator to 63 (for example) so at least when I go to the kitchen in the morning, usually the worst time, it's not unbearably cold.
    My question is if anyone knows of a single thermostat that can control both zones in the kitchen in the way I need?
    Thanks,
    JR
  2. jadnashua
    Very common in Europe is to put a thermostatic control valve on the radiator. these are all mechanical, and adjustable. Essentially, it opens when the temp drops below the set point, and closes again when it gets at or above. This assumes that the circulator is on as it doesn't do anything to control that.
Similar Threads: thermostat room
HVAC Heating & Cooling Per-room Line voltage mechanical thermostats - upgrade options? Nov 25, 2014
HVAC Heating & Cooling Aprilaire 700 humidifier with Nest thermostat Feb 9, 2017
HVAC Heating & Cooling Recommend A Thermostat? Feb 8, 2017
HVAC Heating & Cooling Relocating thermostat to allow heating with wood stove? Jan 17, 2017
HVAC Heating & Cooling How to control the heat using the thermostat? Nov 20, 2016
