one piece verses a three or four piece shower/bath unit
Discussion in 'Shower & Bathtub Forum & Blog' started by Ronin, May 16, 2006.
  1. Ronin
    Ronin New Member
    May 16, 2006
    i would like to know what other peoples thoughts are around one piece and three piece shower/bath units. Historically i have thought that the one piece unit is the way to go. They tended to hold up better, required less maintenance, and had a lower likelihood of leaking. Other opinions?
  2. jadnashua
    For remodel, you often don't have a choice...you just can't get a one-piece into the house and into the room. They generally get installed or at least placed in the bathroom before all of the walls go up. The fewer joints, the better off you are. But, that being said...not all tub/shower systems are created equal. A good 3/4-piece unit might be much nicer than a cheap 2-piece.
  4. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    sterling
    if you can get a one piece tub into the house its great....
    but usually you got to get the breakdown types....
    the absolute best is called STERLING by Kohler....
    a base and three walls...
    never get the types that come in two or three pieces a base and
    two walls that are suppoised to drop together....they never line up right.
  5. Ronin
    Ronin New Member
    May 16, 2006
    what would you recommend for a one piece. And are all the units made by Sterling equally as good. Are they better than a one piece by Kohler? This unit is going into new construction so i can use whatever, just want to make sure I will no have problems.
    thanks
  6. jadnashua
    Put in a nice tub, then tile the walls:) . If you want to go that route, to learn how to do it right so it won't leak, check out www.johnbridge.com also, check out www.schluter.com and search on Kerdi.
  7. Master Plumber Mark
    Feb 6, 2005
    new construction
    thier are TONS AND TONS of fibergalss units that will work great
    in a new construction situation.
    Depending on where you are in the country
    one called AQUAGLASS is pretty gppd... but they are all ok
    go with a one piece if you can ,, if not then put in a STERLING
Similar Threads: piece verses
Shower & Bathtub Forum & Blog Please share if your trim pieces have silicone, Polyseamseal, or nothing? Today at 2:04 PM
Shower & Bathtub Forum & Blog Broken tailpiece stuck in black ABS fitting Mar 11, 2017
Shower & Bathtub Forum & Blog Can I get a 1 piece 32 inch square shower Dec 29, 2016
Shower & Bathtub Forum & Blog Just installed acrylic Delta Tub and 3 piece surround (attach to studs type) Dec 11, 2016
Shower & Bathtub Forum & Blog One-piece supply line May 23, 2016
