One handle shower valves...
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by OldPete, Oct 2, 2006.
  1. OldPete
    OldPete DIY Senior Member
    Jan 4, 2006
    NJ
    Just wondering, why do some folks like valves with IPS fitting and other like sweat? Seems to me that IPS, especially when working with PEX is a no-brainer.
    What's your take?
  2. Master Plumber Mark
    Master Plumber Mark Master Plumber
    Feb 6, 2005
    Sensitivity trainer...healey-feeley.....
    sweat valves....
    depending on the situation whech ever works out
    best....
    if it is a tight , tight spot.... the sweat is always best
    and of course you want to make sure your fire insurance
    is up to date...
    if I can post these pics from friday, I will
  4. hj
    pex
    Some of us still know how to work with copper so the sweat valve eliminates a possible leak at a threaded connection. But since many of the newer valves have a combintion male thread and solder socket, it is less of a decision.
  5. jimbo
    jimbo Plumber
    A few years ago, I would say that the IPS versions were provided as a convenience to DIY'ers. Today, with PEX more prevalent, there is the necessity at some point to transition to the PEX via a non-heated fitting.
  6. OldPete
    Jan 4, 2006
    NJ
    Thank you for the reply jimbo. Nice to meet you. :)
  7. OldPete
    Jan 4, 2006
    NJ
    Ahh... I see, so threaded fittings leak and copper is better. I'll have to look around for a plumber who sweats pipe for natural gas then. :eek:
  8. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    Come on Pete.............Threaded valves were also used when houses were piped galv. And doing replacements it was much better than converting to copper to galvanized pipe.
  9. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    You can't sweat copper for fuel gas. You can use flare joints, however.
  10. OldPete
    Jan 4, 2006
    NJ
    Or you can still use black pipe properly and it is perfect for gas. Just like PEX is perfect for pot. water.
    Provided the person installing it knows how to work with it.
    :D
  11. hj
    gas
    In some areas, apparently you can use copper for gas, although it should be silver solder/brazed. Statement was that a threaded joint on a brass shower valve can leak, while a proper solder joint will not. How does that say anything about a black steel gas line?
  12. OldPete
    Jan 4, 2006
    NJ
    It was implied that if the connection is sweated instead of threaded you will not get a leak. In that implication in whereas, "some of us still know..." that people who don't know how to sweat a pipe use the threaded version (not the case, but I was illustrating the inaccuracy by making the threaded gas pipe comment) - If a thread connection isn't good enough for water, well then, it certainly isn't good enough for gas. (Not accurate since we all know that gas is most often run in black *threaded* pipe).
  13. plumber1
    plumber1 Plumber
    Aug 7, 2005
    Florida
    I'm sorry Pete, I'm not sure what your trying to say.........
  14. OldPete
    Jan 4, 2006
    NJ
    Never mind. ;)
Similar Threads: handle shower
Plumbing Forum, Professional & DIY Advice Replacement Handle for American Standard Tub/Shower Jan 17, 2017
Plumbing Forum, Professional & DIY Advice Water hammer after servicing a pressure balancing single handle shower valve Nov 15, 2016
Plumbing Forum, Professional & DIY Advice Hi I have an older Moen shower handle I need to remove. Oct 23, 2016
Plumbing Forum, Professional & DIY Advice How to Remove Kohler Shower Valve Handle Sep 29, 2016
Plumbing Forum, Professional & DIY Advice HELP! brass fitting far in........... Removing Phister shower handle Jul 13, 2016
