one condensing heater versus two cheaper power vented heaters
Discussion in 'Water Heater Forum, Tanks' started by Hal J, Sep 4, 2010.
  1. Hal J
    Hal J New Member
    Sep 4, 2010
    Minnneapolis MN
    I own a duplex (live upstairs and rent out downstairs) and currently have two power-vented water heaters. One needs replacing now, and the other won't last much longer. The building no longer has a usable chimney, so atmospherically vented heaters are out. My question is, should I spend $750-800 each for two non-condensing, relatively inefficient power-vented water heaters, or should I buy one condensing heater, such as a Vertex GDHE-50 from A.O. Smith, or a Polaris from American Water Heaters?
    I'm tempted to go with one condensing heater. From what I've read, it seems as though one of the condensing heaters would supply enough hot water to meet both units' needs. It would save space, and my understanding is that it would be cheaper to run than two lower-end heaters. On the other hand, with one unit all my eggs would be in one basket.
    Am I overlooking important considerations? Thanks for everyone's opinions.
  2. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    Its your call on whether the condensing unit will have a fast enough payback...
    Make sure you figure the tax credit and check for any state and utility rebates that may be available.
    http://www.energysavers.gov/financial/70020.html
    However, as far as AO Smith & American Water Heaters...
    I'm not a fan of either brand...
  4. Hal J
    Hal J New Member
    Sep 4, 2010
    Minnneapolis MN
    Redwood,
    Thanks for mentioning the tax credit and rebates. I will include those factors in my decision.
    Are there other brands you would recommend?
  5. Redwood
    Dec 15, 2007
    Service Plumber
    Bradford White & Heat Transfer Products (Phoenix)
  6. Gsalet
    Gsalet George the Plumber
    Sep 19, 2010
    San Francisco
    who pays for the gas on each unit? How many people in each unit?, how many bathrooms in each unit? If the neighbor uses all the hot water will one of you wind up in Jail?<grin>
  7. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    If each of the two are 1% likely to fail over some period of years, the one unit would have to be 0.01% likely to fail during that same period to equal the reliability of the two.
    They probably don't make units that reliable.
    The problem is that the companies will probably not tell you their calculated reliability value, but it is linked to the warranty length.
    Another consideration is the current price of replacement parts, which is something you can find out ahead of time.
  8. ballvalve
    Dec 28, 2009
    northfork, california
    Polaris is a good unit, I have installed several, but a bit pricy.
  9. Redwood
    Dec 15, 2007
    Service Plumber
    Polaris, AO Smith, and American Water heaters are all divisions of the same company...
    I do like to avoid them...
  10. BPI Rob
    BPI Rob BPI Building Analyst
    Jan 3, 2011
    Owner of remodeling firm specializing in energy re
    Phladelphia, PA
    I am looking to upgrade to a Condensing Storage Water Heater. What brand-model would anyone recommend to a family of six> We have a conventional gas WH but want to upgrade. Let me explain:
    One of our offerings as a company is Solar Thermal systems. I figured that I would install one on my home as part of a larger project. But we need to abandon our chimney because the HWH is orphaned and does not vent too well and we are about to re-roof and I'd like to get rid of the chimney all together. So I looked at the cost of a condensing WH and the solar thermal and I think, after the condensing unit is installed, the savings of going solar (with or without the polaris solar-gas all in one tank) is fairly small and would not pay back for 15-20 years. That is a stretch for me, so I am probably not going solar. All this leads me to the following question:
    In your opinions, which condensing WH offers the best value and what size would best suit our family of six> We have 2 full bathrooms (only one tub) DW, & Washing machine.
    Many Thanks!
  11. ballvalve
    Dec 28, 2009
    http://www.globalindustrial.com/p/p...er-Heaters-google_pr&infoParam.campaignId=T9F
    I do not "know" this unit, but ONE should do 2 units, and for the cost be the best value.
    Polaris are SS tanks and have had some issues, but seem to be at least a 20 year heater with a few igniter changes. The Polaris is way overkill for just hot water heating in a SFR, but if you heat with it also, it makes great sense. Or use it for a few units +
    Here is another interesting unit. have not found a cost yet:
    http://www.sensibletechnologies.net/HydronicTimes/JTG/HT_JTG_PGETestPhoenixNumber1.html
    http://www.htproducts.com/phoenix.html
Similar Threads: condensing heater
Water Heater Forum, Tanks Condensing NG Tank Heater Recommendations Apr 15, 2011
Water Heater Forum, Tanks Residential condensing or gas high efficiency Sep 7, 2010
Water Heater Forum, Tanks "Traditional" BW, or "Condensing" BW, or "Condensing" American? Oct 26, 2009
Water Heater Forum, Tanks Adding heat pump water heater alongside ancient boiler coil Wednesday at 10:49 AM
Water Heater Forum, Tanks HW Heater to tankless coil Feb 13, 2017
