On Noritz Tankless why can first vertical run of vent be 3' or less?
Discussion in 'Tankless Water Heater Forum' started by billhayton, Jan 30, 2008.
  1. billhayton
    billhayton New Member
    Dec 16, 2007
    Installing Noritz 931 and read the first vertical run cannot exceed 3'..if you add a horizontal section and then go vertical again that ok.
    Any reason for this...does too much vertical venting cause suffocation of unit?
  2. GrumpyPlumber
    GrumpyPlumber Licensed Grump
    Jun 18, 2007
    Plumber, self employed
    Licensed Grump
    Most likely for condensate, high efficiency gas units leave a lot of water behind in the exhaust.
  4. srdenny
    srdenny Plumbing Contractor
    Sep 11, 2004
    Plumbing Contractor
    SF Peninsula
    Put in a vertical condensate tee and all will be well.
  5. billhayton
    Dec 16, 2007
    you guys are good...
    Makes sense the condensate accumulation is not something noritz or anyone else wants running back to unit.
    thanks for the posts
Similar Threads: Noritz Tankless
Tankless Water Heater Forum Noritz N-063 tankless water heater, lose HW pressure and then no HW Jan 24, 2014
Tankless Water Heater Forum further improving/automating recirc pump control with Noritz tankless Dec 18, 2012
Tankless Water Heater Forum Tankless sizing, Noritz NRC98-DV versus NRC111-DV Mar 28, 2012
Tankless Water Heater Forum How loud are tankless hot water heaters, Noritz NRC98? Mar 14, 2012
Tankless Water Heater Forum Noritz NR98-OD Tankless water heater Nov 16, 2011
