Older Moen Push-Pull?
Discussion in 'Shower & Bathtub Forum & Blog' started by vavrousek, Aug 24, 2008.
  1. vavrousek
    vavrousek New Member
    Aug 24, 2008
    I am in the process of doing a basic bathroom remodel...I would like to know if a Moen 2353 would retro for my older Moen push-pull...valve is fine chrome is just worn (Plate, faucet...). It's wrap around shower encloser...If it sounds dumb to do that how hard would it be to change the valve, solder thru the acces hole in the encloser. Swap out for a whole new set up?? Thank you for any advice...
    John V
    Marysville WA
  2. kordts
    kordts In the Trades
    Oct 15, 2005
    industrial service plumbing foreman
    exurban Chicago
    Call Moen to see if what you have has upgrade options. As far as soldering in a new valve behind the surround, it's not a typical first time DIY job.
  4. Redwood
    Redwood Master Plumber
    Dec 15, 2007
    Service Plumber
    No the one you are looking at using is a Posi-Temp which has a larger dia stop tube.
    Go to this link and answer the questions in the pull down menu to see all your Moen trim options. http://www.moen.com/buymoen/buyparts/index.cfm There are also many aftermarket trim kits avaiable for this valve.
  5. hj
    Moen
    The Moen site has multiple options for your valve. Look at the trim for the Moentrol line which uses the same trim parts as your valve.
Similar Threads: Older Moen
Shower & Bathtub Forum & Blog Older Moen Faucet Jun 16, 2008
Shower & Bathtub Forum & Blog Moentrol 3330 - pulling cart prior to soldering?! Nov 20, 2007
Shower & Bathtub Forum & Blog Older Moen tub/shower valve leak Oct 25, 2007
Shower & Bathtub Forum & Blog Older Grohe shower fauct cap removal Nov 19, 2015
Shower & Bathtub Forum & Blog electrical vs. plumbing solder Aug 16, 2015
