Old Toilet problems
Discussion in 'Toilet Forum discussions' started by fredru, Feb 15, 2012.
  1. fredru
    fredru New Member
    Feb 15, 2012
    louisiana
    I have an American Standard toilet from 1985. Inside the tank it reads 4083 and M-3A. I have replaced the valve and flapper assembly 3 times in about 20 yrs. I last replaced the flapper kit less than a year ago. Eventually, these assemblies become unreliable and the toilet begins to run after every 2 or 3 flushes. Sometimes the chain attached to the flapper gets kinked and other times the metal flush handle itself just catches. Jiggling the handle will correct either problem but I don't always know it's running until sometime later.
    Is there a flapper kit you can recommend that is somewhat trouble free?
  2. Gary Swart
    Gary Swart In the Trades
    Sep 1, 2004
    Yakima WA
    I would think a real plumbing supply house would be able to provide decent innards. You will still have an old water hog toilet, but it still should work as well as it ever did. Before I replaced my master bath toilet with a Toto, I had an AS of approximately the same vintage as yours, and it actually worked very well for over 20 years.
  4. hj
    It appears that you need a new handle, not a new flapper. If it uses a standard flapper, and not a tilt-flush unit, then I ALWAYS use the Korky flapper.
Similar Threads: Toilet problems
Toilet Forum discussions Problems replacing a rusted out toilet flange... Nov 27, 2015
Toilet Forum discussions toilet filling problems Apr 24, 2014
Toilet Forum discussions Guinevere Toto toilet - too tight space creating problems - ideas to fix welcome! Pl Nov 16, 2013
Toilet Forum discussions flush problems on american standard wall hung toilet with tank. Sep 30, 2013
Toilet Forum discussions Best toilet for a landlord wanting to avoid problems with toilet overflows? Jun 13, 2013
