Old Shower Drain Upgrade
Discussion in 'Shower & Bathtub Forum & Blog' started by MATTO, Jul 31, 2007.
  1. MATTO
    MATTO New Member
    Jul 31, 2007
    Hello to all,
    Little problem that I need some help with........
    I have a tub drain that is not threaded, has no catch or screen and is constantly becoming clogged because of it. Besides removal of tub and pipe what commercial or inventive options would work. This idea must be user friendly because the tub is used as a shower and bath. This is in a rental a few states away. I don't have the diameter of the pipe at this time. The idea must work as a hair/crud catch and a plug. Thanks in advance for your help. I've really run out of options. The repair guy loves us.:mad:
  2. jadnashua
    If you have access from below, change the tub/overflow assembly would be one option.
  4. MATTO
    MATTO New Member
    Jul 31, 2007
    There is no access from below.
    That would be the most expensive option with removal and all.
    Thanks for the comment.
Similar Threads: Shower Drain
Shower & Bathtub Forum & Blog Offset PVC Solvent weld drain in Acrylic Shower base fit Feb 9, 2017
Shower & Bathtub Forum & Blog Will Fernco coupler in shower drain be prone to clogging? Feb 7, 2017
Shower & Bathtub Forum & Blog Plumber didn't center shower drain rough in under the drain hole - how big a problem is this? Jan 28, 2017
Shower & Bathtub Forum & Blog Moen shower valve issue when water heater drained. Jan 13, 2017
Shower & Bathtub Forum & Blog Remodel: what type of drain to use in shower receptor Jan 12, 2017
