Old shallow well upgrade
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by OwyheeHome, Nov 21, 2009.
  1. OwyheeHome
    OwyheeHome New Member
    Nov 21, 2009
    Grand View, Idaho
    I have a shallow well that serves my home and lawn sprinklers. We are surrounded on three sides by irrigated fields and on the fourth by the Snake River, so the well will never ever go dry. The water pressure from the well cycles up and down. Sprinklers spray goes up and down and pressure from the shower head changes during the shower. Lately the water pressure is so low that it won't kick on the in-line water heater. We solve this by turning on the sink tap and then the well pump kicks on and we have enough pressure. The pump and motor are a rusted mass that was old when the previous owner bought the place in the early 1970s. It is located on the floor of a strange dry cistern in the ground next to my house. A water pressure tank appears to date from about 20 years ago. The lines running from the tank to the sprinkler and our house are flexible 1 inch plastic pipe with a ball shut-off valve that has rusted open. I know I have to replace things, but need some guidance to get started. Times are tough, otherwise I would have just called a well company. I am fairly handy, having dug a basement under our house, wired it to code and wired and plumbed the in-line electric water heater to code. So how do I get started on this??
  2. valveman
    Mar 15, 2006
    Pump Controls Technician
    Lubbock, Texas
    Get a new 3/4 or 1 HP jet pump and use a Pside-Kick like the one on top of this page. The CSV on the Pside-Kick will give you constant pressure instead of the pressure always going up and down. And the constant pressure will make your water heater and sprinklers work properly.
  4. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    Any advice on selecting a quality pump
    Thanks for the advice on the set up.
    I know next to nothing about pump brands. I don't want to replace every few years, so what are some jet pumps? Who should I shy away from?
  5. Thatguy
    Thatguy Homeowner
    Aug 27, 2008
    A bounty hunter like in "Raising Arizona"
    MD
    How deep?
    *********xx
  6. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    The well appears to be hand-dug from around 1917. It flows what seems to be an infinite amount of clear cool water that is slightly alkali. You asked how deep. I do not know other than it is a shallow well. The well is at the bottom of an 8 foot diameter dry cistern in the ground next to my house. The floor is covered with soil and I am hesitant to start digging around at the top of the well to see what is underneath for fear of contaminating. The water has been repeatedly tested and is good other than slightly raised nitrates from the surrounding alfafa fields. I know it is shallow because all deep wells in this area are geothermal and the nitrates from the alfafa. So to answer your question -- I would guess between 10 and 50 feet starting eight feet underground. Weird, yes, but there it is.
  7. nhmaster3015
    nhmaster3015 Master Plumber
    Jul 30, 2008
    Teacher
    The granite state
    I like Goulds pumps
  8. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    Parts on the way
    I bought the Pside-kick and have a line on a 1 HP Gould Pump. Should get me in business!
  9. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    Pside-Kick arriving today
    Will be getting the Pside Kick in today. I plan on installing it even though my new pump has not arrived yet. Hopefully, all will go well (pun not intended).
  10. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    SCV1W valve questions
    Received the Pside-kick today. Opened the box and checked the contents, it is all there, but I do have a couple questions about the Pump Control Valve. The instruction part list identifies the part as PK1W. The valve that came with the kit is labeled both on the box and on the part as CSV1W. I assume that it stands for Cycle Stop Valve 1W. Is this the same as the PK1W?
    Also when I opened the CSV1W box, I found the white cone rattling around along with a thin, about 2 inch diameter ring seal. Is the seal a spare?
    A small silver bit, possibly a small Allen screw has been mashed on the side of the brass nut on the top. There is also a heavy gouge on the side of the brass part directly under the brass nut.
    Now that I look at it closely, some of the threads appear to be micro-nicked, but still serviceable.
    Since this appears to be the lynch-pin technology for the whole thing, I don't want to proceed until I know the unit is fully functional.
    Thanks for your time.
  11. valveman
    Mar 15, 2006
    Lubbock, Texas
    Sounds like a cosmetic problem only but, I still hate that it didn't get there in perfect condition. If you are worried send me a picture. All the working parts and the top simply screw on, so they can be replaced after the valve is installed if needed. Call if you have any questions and I will talk you through it.
  12. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    Thanks
    I appreciate you taking the time to reassure me. The problems all looked cosmetic, but since I am not an expert, I thought I had better check. For example if the Allen screw was some sort of air port, it might have been important.
    I was going to install it today, but am thinking about waiting until the new pump arrives and mount it directly on the pump. Or would it be better to separate the two and put in a coupler and a ball valve?
    Thanks again.
  13. valveman
    Mar 15, 2006
    Lubbock, Texas
    I wouldn't put a ball valve between the Pside-Kick and the pump but, other than that, either way you described will work fine.
  14. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    Been over a year.
    Okay, over a year has gone by and the Pside Kick is working great. However, our old 40 year-old 3/4 HP Jacuzzi pump just doesn't have the power it once had. We want to upgrade to a water softener, but realize that we have to get the pump lined out first (the old pump doesn't do the sprinklers very well) and has trouble giving enough pressure for the shower.
    I am thinking of buying a Goulds 1 HP J10S Shallow Well pump. Is this appropriate?
    The pump will go into an 8 foot deep cistern (damp environment) that draws from a 6-15 foot deep well. The wiring is 110.
    Thanks for any help.
  15. valveman
    Mar 15, 2006
    Lubbock, Texas
    That is a good pump. But if you can use a submersible in the cistern, you can get twice as much with the same horse power.
  16. OwyheeHome
    Nov 21, 2009
    Grand View, Idaho
    I have thought about a submerged pump -- my neighbor has one that is working fine for him and resolved some of his sprinkler pressure issues -- but the logistics of our well at the bottom of the cistern make me favor the easy to get to and easy to replace pump. I am a little astounded that the old pump has worked so long and so well. I wonder if I will get that kind of service out of the new pump.
  17. valveman
    Mar 15, 2006
    Lubbock, Texas
    Pumps may not be made as good as they were 30 years ago, but you now have a CSV on your Pside-Kick. Drastically reducing the number of cycles with the CSV, you might even get a longer run, even with a recently built pump.
Similar Threads: shallow upgrade
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well jet pump failing to reach cutoff Feb 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow well pump installation Feb 10, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Advise Jan 15, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Shallow Well Jet Pump Recommendations? Jan 4, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Filter before shallow well pump? Dec 19, 2016
