Old out faucet leak
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ellaryk, Jun 23, 2012.
  1. ellaryk
    ellaryk New Member
    Jun 23, 2012
    IT Manager
    Buffalo Grove, IL
    My house was built in 1968. The outdoor faucet is not frost free. It comes straight out of the wall with the handle at the end and the spigot down at a 45 degree angle with a hex nut shape as part of the casting about two inches from the handle end. See attached photo.
    It leaks from the handle when the faucet is on. there is no leak, as you can see from the photo, when the faucet is off.
    What do I need to do?
  2. Smooky
    Smooky Well-Known Member
    Apr 4, 2011
    North Carolina
    I think that is a frost free faucet. You may be able to tighten the packing nut and stop the leak. More than likely the packing washer is bad and needs to be replaced. To remove it, first turn off your water. Then you can remove the handle. You may need to put the handle back on after you remove the packing nut so you can pull everything out. The big hex nut is the packing nut and should unscrew but it may be reverse thread. Here is a link to a similar style wall hydrant. I have no idea what brand you have but it looks like Prier. It sorta looks like I can see Prier in the paint.
    http://www.griggindustries.com/page313.html
  4. ellaryk
    ellaryk New Member
    Jun 23, 2012
    IT Manager
    Buffalo Grove, IL
    It is a Prier. I increased the size of the image and PRIE is easily read. Is there a way to tell if it's reverse threaded?
  5. Smooky
    Apr 4, 2011
    North Carolina
    I found this in the link below. You should be able to find what ever you need in these links. Looks like good info:
    Question 1: When the water is running there is water leaking from behind the handle.
    Answer 1. This is a common maintenance occurrence for any packed valve of any brand or manufacture. It is overcome by simply tightening the packing nut with a crescent wrench. This will force the packing tighter around the stem to eliminate leakage.
    Occasionally, the packing will need to be replaced if the packing nut has been repeatedly tightened.
    The parts required for this is a C-134KT-803 Packing Kit
    http://www.prier.com/products/residential-hydrants/c-134-prier-original-design.html
    http://www.accentshopping.com/product.asp?P_ID=153720
  6. MASTERPLUMB777
    MASTERPLUMB777 Member
    Aug 6, 2007
    Retired Master Plumber
    Texas
    #1 remove handle
    #2 remove big packing nut making sure to keep faucet handle off
    #3 take a appox. 6" piece of teflon tape twirl between you fingers till it becomes a 6" thread
    #4 wrap around faucet stem clockwise
    #5 reinstall packing nut being sure not to over tighten test this by opening faucet a little bit and slowly tighten packing nut till water stop leaking out
    #6 reinstall handle
    their you are good for another 25 years or so
  7. ellaryk
    ellaryk New Member
    Jun 23, 2012
    IT Manager
    Buffalo Grove, IL
    Thanks. But removing the handle is the hard part. The screw won't budge. I've been spraying it with PB. Do you have any tricks for loosening it? Or can the Teflon tape be installed without removing the handle?
  8. MASTERPLUMB777
    Aug 6, 2007
    Texas
    No you must remove handle to packing nut out far enough put teflon string in
Similar Threads: faucet leak
Plumbing Forum, Professional & DIY Advice Leaking Moen 7385 faucet need help Feb 9, 2017
Plumbing Forum, Professional & DIY Advice Faucet Handle Removal & Leak Repair Feb 8, 2017
Plumbing Forum, Professional & DIY Advice Leaking outdoor faucet attached to house Jan 6, 2017
Plumbing Forum, Professional & DIY Advice Replaced Delta 2 handle faucet cartridges now there is small leak from valve stem Oct 30, 2016
Plumbing Forum, Professional & DIY Advice Bathroom faucet leak Oct 19, 2016
