Old Moentrol - Which Cartridge?
Discussion in 'Shower & Bathtub Forum & Blog' started by jwcrim, Nov 6, 2005.
  1. jwcrim
    jwcrim New Member
    Nov 6, 2005
    We built a house in 1976 and put in a shower with a Moen single knob hot/cold control valve. The escutcheon has Moentrol stamped on it.
    Taking off the escutcheon plate the valve appears to be fully symmetrical left to right with a large slotted face (balancing spool?) located right above the knob axis on the vertical centerline.
    The unit works OK but it's getting pretty hard to push/pull the knob. I see that later models use Model 1200 and 1225 cartridges. I haven't tried to take it apart. Assuming this thing has a cartridge, which model cartridge would it be?
    Any advice appreciated.
    [​IMG]
  2. jimbo
    jimbo Plumber
    [​IMG]
    The original cartridge is probably a 1200, all brass. But the plastic 1225 is interchangeable with the 1200.
  4. jwcrim
    jwcrim New Member
    Nov 6, 2005
    Thanks a lot for the information. I ran across these notes for pulling the 1200 out:
    "To remove an old corroded Moen brass shower cartridge when all else fails, pull the center out of the cartridge with a pair of pliers or vice grips. Run a 1/2 tap in the cartridge and remove tap. Place a 1 and 3/4 inch long wooden dowel in the cartridge and run the tap in until the cartridge frees up. This took more turns on the tap than I expected but it worked. Clean the valve body with a tooth brush and white vinegar and flush out the brass filings by turning the water on for a second before replacing the new cartridge. I neglected this last part and the shower head filled with filings."
Similar Threads: Moentrol Cartridge
Shower & Bathtub Forum & Blog problem screwing new handle onto Moentrol valve body / cartridge Oct 4, 2010
Shower & Bathtub Forum & Blog Is this a picture of a Moentrol or Posi Temp Valve? Nov 15, 2016
Shower & Bathtub Forum & Blog Moentrol, Only hot water coming from Moen shower Aug 11, 2016
Shower & Bathtub Forum & Blog Should I reuse my old Moentrol valve? Jul 1, 2016
Shower & Bathtub Forum & Blog Moen Align trim w old Moentrol valve? Jun 23, 2014
