old Moen single handle kitchen faucet
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by charles2, Jul 7, 2013.
  1. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    It dates from about 1980 but I can't find the specific model # on Moen's website. The end of the handle looks triangular, if that helps. I've replaced the cartridge a couple of times over its service life, once with brass and again with plastic. Now it's dripping again. Does anyone make a ceramic cartridge for it?
  2. Terry
    Aug 17, 2004
    It takes a 1225 plastic or a 1200 brass cartridge.
    I don't believe they have a ceramic replacement for that.
  4. hj
    NO, and two replacements in 33 years is a pretty good service life. The stamped handle with a triangular end was the low end "Chateau" line, but they still used the same core as all Moen faucets. PErsonally, I prefer the #1200 brass stems, but some Moen kitchen faucets, not yours however, REQUIRE the #1225 plastic one because of the different "O" ring location on it.
  5. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    Good info, thanks. The HO might want to upgrade to a ceramic model. What should I recommend? They might even go for a pull-out, but not pull-down.
    Here's what I would spec: Swiveling, single handle, low-arc, ceramic cartridge, deck mount, 3-hole 8" centerset, chromed cast brass, with aerator and brass mounting hardware, pull-out nylon spray hose with stainless steel sheath and backflow preventer, meeting NSF 61 and ASME/ANSI A112.18.1. But what do y'all say?
  6. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    The title of the thread says kitchen faucet, no need to have any anti scald device. Pick a tap and install it.
  7. hj
    If you like that faucet, install it.
  8. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    What faucet?
  9. cwhyu2
    cwhyu2 Consultant
    Aug 11, 2007
    Consultant
    Cincinnati OH
    Delta and Moen have very nice kitchen sink faucets.Just got to pick the for your application.
  10. hj
    quote; What faucet?
    The one that has the specifications you listed.I assumed from their detail you were copying from a manufacturer's description.
  11. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    Well, it is copied, but not from a mfr. I've been in remodeling for many years and clients ask me what to look for, and that's what I tell them means good functionality and quality to me based on everything I've read and been told over the years. But I've never actually had to recommend a specific model that fits the description. Hence my request for a recommendation. I thought you guys plumbing daily might have some idea, but I guess not.
  12. hj
    I use MANY different faucets and most fit that description. I let the customer decide which STYLE faucet they want, from different manufacturers, therefore there is no ONE faucet that fits your specifications.
  13. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    These don't have the stamped handle with the triangular end: http://www.moen.com/search?N=0-4294966725&search_scope=0&search_terms=chateau Does Moen keep the same name as they change the design?
    Really? I can't find ANY that fully fit that description. What models are you aware of?
  14. hj
    Handle designs come and go even though the series name remains the same. You have the "original" version.
    1. Swiveling, they ALL do that
    2. single handle,Lots of those
    3. low-arc, Look at the faucet, although most users prefer high arc
    4. ceramic cartridge, common to almost all new ones
    5. deck mount, 3-hole 8" centerset, very few do NOT mount with a 3 hole option but most also can use a single opening.
    5. chromed cast brass, with aerator.. Chrome is somewhat pedestrian these days, and "brass" is becoming harder to find in new designs because of the antilead laws.
    6. brass mounting hardware, also common, although if the faucet doesn't leak the hardware will not corrode
    7. pull-out nylon spray hose with stainless steel sheath take your choice. Either a "nylon" braided hose or metal with a surgical rubber linera.
    8. backflow preventer, by definition for any faucet with an immersible spout.
    9. I find the faucet FIRST, then see how many of the requirements it meets.
  15. charles2
    charles2 Member
    Apr 7, 2008
    Georgia
    hj, that's very helpful, thanks.
Similar Threads: Moen single
Plumbing Forum, Professional & DIY Advice Moen Single Handle Pull Down Kitchen Faucet water supply hose question Tuesday at 6:03 AM
Plumbing Forum, Professional & DIY Advice Adjust hot/cold on single handle Moen bathtub control? Nov 2, 2016
Plumbing Forum, Professional & DIY Advice Do any of you old timers remember the model name of the original Moen single handle kitchen faucet? Feb 9, 2015
Plumbing Forum, Professional & DIY Advice Hot and cold reversed on Moen single handle faucet Nov 10, 2011
Plumbing Forum, Professional & DIY Advice Slow running moen single handle Kitchen faucet Aug 21, 2011
