Old house, 100A fusebox, should we replace w. breakers?
Discussion in 'Electrical Forum discussion & Blog' started by capecod, Jan 12, 2012.
  1. DonL
    DonL Jack of all trades Master of one
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    JW is correct that fuses will blow quicker than Breakers of the same size.
    I do believe fuses are safer. But keeping spares is a smart thing to do.
    Most home style breakers contain a heating element and a bimetallic Cutout, Heat makes them open.
    The breaker may take a dead short or UP TO 10X rated Value to trip Immediately.
    The surge current of normally operating devices (Mostly Motors) is the reason that breakers have delays built in.
    Normally they will trip at there rated current in Milliseconds (MS). Could be many, depending on the load.
    If it was very many seconds, the Fire could have already started, and that would defeat its purpose.
    I disagree with that link as it states.
    "A fuse might make the difference if you get hit with lightning."
    I Fuse can not protect from a direct hit from lightning. It will jump across it.
    A gas discharge tube connected to a good ground maybe, but not a fuse of any type can fool Mother Nature.
    Making sure the current flows into the ground, instead of your equipment is the key.
  2. capecod
    capecod New Member
    Oct 29, 2006
    We have plenty of spares, tho some are rather old.
    Maybe we will stick with what we have.
  3. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Not a bad choice, You may want to Pick up more spares when you go to the big town.
    Old is good, If it is working.
    They are getting harder to find.
  4. capecod
    capecod New Member
    Oct 29, 2006
    We do have a lot of them and we also have stockpiled a lot of 100W lightbulbs in our cellar too.
  5. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Way to go.
    Don't forget the bullets...
    Keep everything dry and they will be OK.
  6. capecod
    capecod New Member
    Oct 29, 2006
    Yeah, we have a few of them too, who doesnt?
  7. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    I lived in a house many years ago and the wires ran parallel on insulators.
    It was cool to see real time old school.
    That was back before a ground was ever ran to any outlets.
    The wire had Cloth insulation, I guess Grandma made it. lol
  8. jwelectric
    jwelectric Electrical Contractor/Instructor
    Jun 14, 2007
    Instructor
    North Carolina
    I need to make some corrections. I talked with Tommy today about our experiment. Tommy was one of my students who has done nothing but go forward in the electrical profession. He remembers the experiment and kept his notes to wit I need to make some corrections.
    The max load was 100 amps not 120. We also determined that there was a plus or minus 15% in the ammeter that was being used also. The meter was out of an old control panel and wasn’t completely accurate. The GE breaker fared better during the testing than the other two with the Square “D” taking the longest to open.
    We also used a NON-20 amp fuse that opened faster than he would work the button on the stop watch with the old pot set at the same resistance for the 30 amp test on the three breakers. It opened faster than the old ammeter would and we never got a reading on the amperage so for the sake of the experiment assumed it to be a 30 amp load as it was the same setting for 30 amps for the breakers although the connection was made a little different.
    Please forgive my mistake as my memory is not as good as it once was and this test was done in September of 2002.
  9. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Got to love them students JW.
    They don't have the CRS yet.
    I do not rely on my memory because I ran out 1 Megabyte ago.
    I bet the students really enjoyed you as a teacher.
    Good teachers are hard to come by, and they will remember You Forever and a Day...
    You are the best.
  10. Bobelectric
    Bobelectric Electrical Contractor
    Feb 16, 2009
    Eighty Four,Pa. 15330
    jewelectric is kinda right. If you can upgrade to a bigger "Breaker" panel, do it.Prices aren't falling.
  11. capecod
    capecod New Member
    Oct 29, 2006
    We are open to these options, just want to do a bit more thinking and studying.
    Thats why Im so glad we found this forum, very educational.
  12. ESCO
    ESCO Self Employed Electrician / Master
    Jan 31, 2013
    Belleville Il
    People are afraid of fuses but they do open circuits [ disconnect] faster than most breakers
    But you are right they are less user friendly
  13. capecod
    capecod New Member
    Oct 29, 2006
    I sure appreciate all this information, and I now agree with you all and my husband, the fuse box will stay.
    We have plenty of fuses and managed to find a replacement for the big main knife fuse, used but in perfect shape, from a local electrician.
    Thank you!
    Jane
  14. BobL43
    BobL43 DIY Senior Member
    Mar 25, 2011
    Retired Industrial Automation controls/tech s
    Long Island, NY
    Stir, stir, stir sir
  15. DonL
    Mar 30, 2011
    Rocket Scientist
    Houston, TX
    Where did that come from ?
    Hello Bob. I hope all is well.
    Must have been a year ago or so.
  16. BobL43
    Mar 25, 2011
    Long Island, NY
    WOW, you are right. I did not notice that lol
Similar Threads: house 100A
Electrical Forum discussion & Blog Romex to THHN conversion in house junction box Oct 2, 2016
Electrical Forum discussion & Blog Conduit Underground from House to Garage (+water) Sep 29, 2016
Electrical Forum discussion & Blog Advice on feeding house panel from pole mounted meter 200a Aug 28, 2016
Electrical Forum discussion & Blog Is it possible for an amateur to rewire a whole house? Jul 12, 2016
Electrical Forum discussion & Blog Wiring to be done at my house Dec 30, 2015
