old faucet handles
Discussion in 'Shower & Bathtub Forum & Blog' started by reyn, Jan 27, 2013.
  1. reyn
    reyn New Member
    Feb 5, 2012
    nj
    Hi.
    I'm confused on how to remove these handles. I would like to replace them if I can.
  2. jimbo
    jimbo Plumber
    San Diego, CA
    The index buttons..."h", "c", etc remove and there is a handle screw. THe buttons probably pry off with a butter knife. If they don't pop right out, they might unscrew, but yours look like they will pop off.
    With any luck, the screw will the come out OK. You may need then a handle puller to remove the handle.
  4. cacher_chick
    Jan 5, 2008
    Test, Don't Guess!
    Those handles are probably chrome plated bronze, and you will not be likely to find another handle of that quality. Polishing might be a good option.
  5. jadnashua
    FWIW, there are companies that will clean and replate those to better than new condition, but, I'd seriously consider replacing with a modern valve. Depending on their workload, it may only take a few days. I think the money would be better spent elsewhere, but it's your house.
  6. bcarlson78248
    bcarlson78248 Member
    Feb 24, 2013
    Alexandria, VA
    I have what appear to be the same faucets, and the center button (H and C) unscrew. There is a phillips head set screw behind the button. I was able to remove the screw and work the handles off the splined shaft. After removing the screw I was trying to work the handle off the shaft and thought they would never come off, and then the handle suddenly broke loose.
    Bruce
  7. judyfholmes
    judyfholmes Guest
    Handle suddenly broke? Now will you be able to fix another handle over there? A plumber might do the job well here but since you tried, may be it didn't turned out quiet well. Or did it?
  8. hj
    Normally, the handle would "not suddenly break", but the stem's end WOULD snap off if you were trying to remove the handle incorrectly. Those appear to be American Standard handles and if so, the screw "caps" unscrew to give access to the handle screws underneath them.
  9. bcarlson78248
    Feb 24, 2013
    Alexandria, VA
    I have to be more careful about my wording. When the handle "broke loose" it slipped off the splines, which is exactly what I wanted it to do. Nothing broke on the fixture.
    My point was that the handle is a friction fit on the splines and it may not come off easily even after you remove the set screw.
    Bruce
  10. shrews1
    shrews1 New Member
    Aug 4, 2013
    Iowa
    i have got the same set except not the middle one- the hot side has a leak- rather a "run" a very fast leak! I think all i need is a new seat or something but once i get handle off- how do i get wall plate off ? any help would be appreciated! thanks!
Similar Threads: faucet handles
Shower & Bathtub Forum & Blog Code Question for faucet handles May 27, 2016
Shower & Bathtub Forum & Blog Removing Grohe Tub Faucet Handles Dec 23, 2012
Shower & Bathtub Forum & Blog Shower Faucet Handles Come Off - Yet the Coverings just spin Sep 9, 2012
Shower & Bathtub Forum & Blog Removing Grohe volume control extension on faucet handles Jun 13, 2011
Shower & Bathtub Forum & Blog Help! how to take off old Gopher tub Faucet handles May 2, 2010
