Old fashioned leaky taps non-repairable?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by spiral, Apr 7, 2014.
  1. spiral
    spiral New Member
    Apr 7, 2014
    BC
    Hi,
    I have a landlord who is refusing to repair my gorgeous old leaky taps anymore. He has tried to fix them a couple times and they only get more leaky, so now he's claiming that they aren't repairable. I strongly disagree, and think parts are more readily available than he thinks here in Canada (Victoria, BC). I am hoping you folks out there can back me up after looking at the photos of these MUELLER old fashioned taps I have attached. I need a washer and/or cartridge replacement for both the hot and cold taps to keep this tapset here... and so that the owner doesn't replace it and the whole sink with it. As you can see from the photo the closed tap is leaking quite a bit, about a litre of water every three minutes now. Help!
    Cheers, Tim :-(
    20140405_120646.jpg 20140405_120657.jpg .
  2. SHR
    SHR Member
    Mar 9, 2014
    Journeyman Plumber
    Minnesota
    I bet they are easily repaired. Replace washers and resurface seats you should be good. And for goodness sake, when you work on these faucets use an adjustable wrench or at least a tool without teeth so as not to mar the finish anymore.
  4. Jerome2877
    Jerome2877 In the Trades
    Aug 25, 2009
    Vancouver Island , BC
    His taps, his decision.
  5. hj
    "resurface the seats" is easy to say, but much harder to do properly. When you try, there are only two results. Either you did it correctly and the faucet doesn't drip, or you didn't and you have to throw the faucet away. I have a pair I am working on now. Either I find my seat dressing kit, which I have not seen since I bought this truck 3 years ago, and have not used for over 30 years, or I try to find her a pair of "vintage looking" faucets. However, until the faucet is taken apart, you do not know if this faucet has replaceable seats, which would make the repair much easier.
  6. ankhseeker
    ankhseeker Member
    Oct 2, 2013
    San Pablo, California
    If you are planning to stay for a long time, you might just hire a plumber and pay for it. That way there is no argument and you are happy.
Similar Threads: fashioned leaky
Plumbing Forum, Professional & DIY Advice Pipe leaking when flushed on old fashioned toilet May 29, 2015
Plumbing Forum, Professional & DIY Advice Old Fashioned Rasied tank style toilet Dec 18, 2007
Plumbing Forum, Professional & DIY Advice Leaky trap Feb 6, 2017
Plumbing Forum, Professional & DIY Advice Leaky spiral hose for main kitchen faucet pull-out line - fix without replacement? Sep 1, 2016
Plumbing Forum, Professional & DIY Advice Leaky back flow preventer Aug 24, 2016
