Old 2" well advice needed
Discussion in 'Pumps and Tanks Well Forum & Blog' started by Jerred18, May 27, 2012.
  1. Jerred18
    Jerred18 New Member
    May 27, 2012
    NC
    Okay, I have a 2" well casing with a single pipe dropped 70 ish feet with ejector and foot valve. I have pulled twice due to foot valve being clogged from the rust from the steel pipe. Going back with plastic!! I dropped a string with big nut attached, hit water at approx 32 feet. I would like to improve pressure and volume. Previously could only run one sprinkler head. Using 1 hp pump. Is there another setup I could use. Would a 1hp shallow well pump pull the water if I dropped pipe to 45 feet with just a foot valve attached. All suggestions will be appreciated, just looking for options to improve water flow.
  2. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    If the footvalve is plugged with rust, the drop pipe is not to blame. Below the packer, only rusty casing can clog the footvalve.
    The laws of physics prevent a shallow well pump from lifting water from that depth.
  4. Jerred18
    Jerred18 New Member
    May 27, 2012
    NC
    The rusty gunk was between the ejector and foot valve. So I should just replace both and use PVC pipe? Can you explain how the ejector seals to the casing? I am assuming that you can feel when it sets to the casing? The ejector was completely clogged as well.
  5. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    The leathers on the packer seal against the casing. There is nothing to "feel".
    I doubt you can DIY replace the casing with PVC. If you get a driller in to do it, put in a larger casing so that you can use a submersible.
  6. Jerred18
    Jerred18 New Member
    May 27, 2012
    NC
    Oh no I would not try that. I am talking about the 1" line. It was old black steel, I want to back with PVC. But mentioning a larger casing, does it make it any easier or cheaper since the 2" is already there?
Similar Threads: advice needed
Pumps and Tanks Well Forum & Blog Low flow / pressure from 6 yo well -- advice needed Mar 2, 2016
Pumps and Tanks Well Forum & Blog Pump and Irrigiation Design Advice needed for Non-profit Farm Site Apr 8, 2015
Pumps and Tanks Well Forum & Blog New Tank Connection Advice Needed Jan 28, 2015
Pumps and Tanks Well Forum & Blog Pump advice needed for new well Jun 18, 2014
Pumps and Tanks Well Forum & Blog New well advice needed Apr 20, 2014
