OK, toilet review after 1 day...(Kohler vs. TOTO)
Swing
As I posted in the other thread, I bought a Toto "Supreme" yesterday...I was on a roll and feeling froggy so I also got a Kohler Cimmaron for my master bathroom.
The supreme installed relatively easy (considering its a one piece...pretty danged heavy for one person). I had to reconnect the water supply a couple times (actually had to use the old rubber nipple/gasket, the one that was supplied didn't work.. too small).
Put the Kohler in MUCH quicker even though it was a two piece. I guess since it is bigger it was easier for my big belly to get around to everything :)
Performance:
Toto = ok, not bad, better than what I had
Kohler = AWESOME
Obvious difference in performance, the Kohler has a MUCH stronger flush and the water moves around the bowl better.
Comfort:
Kohler = "chair height", I'm 6'5" so its great
TOTO = shorter and the bowl is smaller...great for my 5'1" wife and kids.
Bottom line, the Kohler will be "mine", the TOTO will be the families!
If I had more room i would take the Kohler over the TOTO but since I have so little room, the TOTO fits perfect!
Thanks for the help fellas!!
Having done a lot of installs, I can safely say, that pulling a one piece toilet out of the box and sticking it down on the wax, is much quicker and easier than assembling a tank to a bowl, and then sticking it down.
Unless, you can't lift the toilet without help.
We don't have that worry.
I can carry a one-piece toilet through the house with one arm.
Water supplies are standard on toilets.
Many of the toilets are using either a Fluidmaster, or the Korky Quietfill.
The threads are the same.
Most installers don't use the plastic bits that come with the toilets for that purpose, but use a water supply that comes complete with seals.
I've had both the Cimmarron and the Toto installed for use, I would give both some time.
The trapway on the Kohler is a bit flatter on the lower end, and did wind up clogging more.
