Ok to use heel inlet 90 degree el
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by johnny92626, Oct 11, 2008.
  1. johnny92626
    johnny92626 New Member
    Oct 11, 2008
    Hello,
    I have a remodel going on. I have a shower that I need to vent and drain. I also have a toilet on the other side of the wall. can I use a 4"*4"*2" heel inlet going to the toilet (with the 2" part in the vertical position), as the shower drain as well( then I would continue with a 2" vent to the roof)?
    [​IMG]
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    yes you can
  4. hj
    ell
    That is either going to make the closet bend very low or the shower connection very high. A diagram of what you are doing might reveal a better way.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The fitting to use is a side inlet 90, that gets things at the right level.
  6. hj
    fitting
    Bit that then negates the possibility of continuing the line vertically for the vent. A side inlet sanitary tee might be the fitting of choice with a bushing in the top for the 2" vent.
  7. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    I usually put the side inlet t under the toilet, sweep back to the wet wall, hit a san tee, vent up and drop down. The fitting you are talking about we used to call an estabrook. Very handy thing to have on the truck. Won't use one every day but when you need it, you need it.
  8. hj
    tee
    We called it a cottage tee, out here they call it a Wisconsin fitting, but I am confused how, or why, you would put it under the toilet then run back to a sanitary tee, instead of using it in place of the sanitary tee, which is where we use them and may use more than one in any given building.
  9. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    Because I can dump the tub into it and wet vent the whole mess.
  10. hj
    tee
    But if I read your posting correctly, you are putting the tee on its back under the toilet then piping to a sanitary tee at the wall, right? If so how do you get ANY inspector to approve it?
Similar Threads: heel inlet
Plumbing Forum, Professional & DIY Advice 90-Degree ABS Lo Heel Inlet Elbow Fitting question Jan 24, 2015
Plumbing Forum, Professional & DIY Advice offsetting mainstack and correct use of 90 elbow with heel inlet Aug 15, 2008
Plumbing Forum, Professional & DIY Advice San Tee vs 90 with low heel inlet? Jul 8, 2005
Plumbing Forum, Professional & DIY Advice Is this a correct application of a low-heel fitting? Dec 16, 2015
Plumbing Forum, Professional & DIY Advice Moving toilet in house built in 1962 - help with 90 degree w/ low heel. Apr 10, 2015
