OK to up the pressure?
Discussion in 'Pumps and Tanks Well Forum & Blog. Water is life.' started by BluesMan, Dec 14, 2008.
  1. BluesMan
    BluesMan New Member
    Nov 8, 2008
    My pressure sw. is currently set to 35/55 and I have 33 psi in the pressure tank when empty. Any reason I cant up this to 40/60 to get a bit more pressure to the 2nd floor showers?
    Thanks
  2. BluesMan
    BluesMan New Member
    Nov 8, 2008
    Hey Andy...thanks for the help. I do know how to adjust the pressure switch and adjust the tank pressure too. I was just wondering if there would be any ill effects by upping the pressure...like the pump cycling more, etc....?
    I have a 3/4" feed from the tank to a PEX manabloc system. No water treatment yet....hoping to put a softener in sometime after the holidays.
    Thanks
  4. W.O.P Jeff
    W.O.P Jeff Junior Member
    Dec 12, 2008
    Service and Sales Rep For Pump Company
    Ottawa, Ontario
    Upping it 5psi should not have any effect if it runs fine currently.
    What type of pump do you have? HP?
  5. BluesMan
    BluesMan New Member
    Nov 8, 2008
    Thanks W.O.P.....it's a submersible pump, but I am unsure of the HP. I should call the driller and ask them what they installed.
    The pump seems to be cycling fine now.
    Any reason why they would set the pressure switch to 35/55 instead of 40/60?
  6. W.O.P Jeff
    Dec 12, 2008
    Ottawa, Ontario
    Submersibles you can build up to way passed 60.
    40-60 is standard though.
    Jet pumps on the other hand... They will not build up passed certain PSI's depending on the use.
    If you have a control box on the wall it should tell you the Volts, HP, sometimes your GPM depending on who's control box it is.
    Even your standard 10GPM 1/2hp will do it though.
    Edit: Don't go much passed 60 though as I am sure you have a pressure relief valve on your system
  7. Gary Slusser
    Retired
    Yes increasing the pressure settings causes the pump to cycle more frequently because you will use more water.
    Maybe there is a cause for low flow on the second floor.
Similar Threads: pressure
Pumps and Tanks Well Forum & Blog. Water is life. Well Pressure question Mar 14, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well Pump Pressure Switch constantly cycling on and off Mar 9, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Well pressure tank help. Feb 26, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Pressure switch question Feb 24, 2017
Pumps and Tanks Well Forum & Blog. Water is life. Water pressure fluctuates Feb 19, 2017
