Ok to run shower piping out of tub port on valve?
Discussion in 'Shower & Bathtub Forum & Blog' started by copper piper, Dec 20, 2013.
  1. copper piper
    copper piper New Member
    Dec 19, 2013
    Maryland
    Hello-
    I have 2 seperate shower units in my stall. Plumber piped one valve correctly, but piped one with shower pipe exiting out of the tub port on valve. I seem to have a bit of water hammer or spool play in cartridge now.
    Is it OK to pipe to shower from tub port (lower) on valve or should it be redone to go out of shower port (top) on valve?
    Thanks in advance.
    bb
  2. Terry
    Aug 17, 2004
    Some plumbers prefer using the tub port, as it's not as restricted.
  4. hj
    I ALWAYS do it that way as long as the valve is 180 degrees symmetrical so it can be inverted. Doing it that way can avoid some nasty problems in the future.
  5. copper piper
    Dec 19, 2013
    Maryland
    Thanks for your reply. Are you saying that the valve should be turned 180 so that the tub port is at 12:00?, instead of 6:00? The way mine is now, is that the tub port is facing at 6:00, with the tubing then going up to shower.
    And, what problems in the future are speaking about? I may have them at the present.
    Thanks again.
Similar Threads: shower piping
Shower & Bathtub Forum & Blog Shower valve piping distance May 20, 2014
Shower & Bathtub Forum & Blog Stall shower low or no water flow clogged shower piping Sep 15, 2013
Shower & Bathtub Forum & Blog Moen Tub/Shower piping size & cartridge replacement... Sep 6, 2012
Shower & Bathtub Forum & Blog Upgrading shower valve for existing galv. piping Apr 6, 2007
Shower & Bathtub Forum & Blog Shower Pan Question Wednesday at 5:39 AM
