Oil tank valve leak
Discussion in 'HVAC Heating & Cooling' started by cirrus, May 22, 2007.
  1. cirrus
    cirrus New Member
    May 22, 2007
    Hi!
    Great forum!
    Our oil tank for the furnace has a shut off valve on it (bottom of tank) that has a slow drip to it from the valve stem which we catch in a small container. I'd like to fix it but I'm wondering how is this done? Seems that the oil left in the tank (there is 1/8 tank left) needs to be drained/siphoned out. Does anyone know how this would be done?
    TIA!!
  2. hj
    leak
    Tighten the nut around the valve stem to stop the leak.
  4. cirrus
    cirrus New Member
    May 22, 2007
    Thanks for the reply....yea already tried that...still leaks. I probably need to remove the whole stem assembly and replace the washer or whatever those type of valves use to seal the unit. Or just replace the whole valve but in either case the oil needs to be drained I guess.
  5. hj
    valve
    Turn the valve off. Remove the packing nut. If there is a brass "follower" bushing under it, lift that also. Install additional packing, replace the follower, and then tighten the nut.
  6. cirrus
    cirrus New Member
    May 22, 2007
    HJ,
    I've never replaced the packing material just the washers....so I was thinking I had to remove the whole cartridge/stem. But thinking about it I can just take off that packing nut and still have the valve closed. I'll try that this weekend for sure! Thanks!
  7. jadnashua
    Just try tightening it a little first. Only repack it if that doesn't work.
  8. joe in queens
    joe in queens New Member
    Jan 5, 2007
    There is a way to change out an oil tank valve without draining the oil from the tank... even with a full tank. It's a two man job, requires some skill, and there's a risk of damaging the tank if not done right but it can be done.
    But try what has been suggested here. It should take care of it.
  9. cirrus
    cirrus New Member
    May 22, 2007
    And one guy has to have a real big thumb....LOL! Just kidding.
    Thanks guys for the ideas...sounds alot more promising than what I feared!
  10. cirrus
    cirrus New Member
    May 22, 2007
    Not to jinx myself...and the tank is almost empty...but I backed off the nut and then retightened it....so far so good..no more leaks!
    Thanks everyone!
Similar Threads: tank valve
HVAC Heating & Cooling What is the best value 80-100 gallon tank for storage/buffering? Jan 7, 2014
HVAC Heating & Cooling Propane tank, is it ready for work ? Sep 9, 2013
HVAC Heating & Cooling Hydronic air handler: tankless water heater or heat pump Aug 11, 2013
HVAC Heating & Cooling Boiler Decision: Oil or Natural Gas? 80%? 90%? Condensing? Tankless? Feb 12, 2012
HVAC Heating & Cooling deactivate buderus hot water tank Oct 21, 2010
