Oil Tank Replacement
Discussion in 'HVAC Heating & Cooling' started by Massjim, Jul 1, 2009.
  1. Massjim
    Massjim New Member
    Jul 1, 2009
    Current oil tank, 275 gallon, located in unfinished basement with concrete floor. I live in Massachusetts.
    Tank is leaking from the seal.
    I plan on having it replaced.
    What else should I do?
    I have a copper line which is in the concrete floor.
    Should I replace this...what do they replace it with copper/plastic??
    Do they use the same filter??
    What is the estimated cost??
  2. 99k
    99k Radon Contractor and Water Treatment
    Aug 16, 2008
    Contractor of Radon Reduction, Testing, and Water
    Fairfield Co.,Connecticut
    What do you mean leaking from the seal? Can you post a pic?
  4. Massjim
    Massjim New Member
    Jul 1, 2009
    seam
    Sorry from the seam
  5. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Don't bother replacing the copper line unless it's damaged or leaking.
    The cost of replacing the tank often depends on how easy it is to get it in/out of the place. Last year when oil was pushing $5/gallon some folks would credit you something for the value of the oil, but I doubt that's the case this year- it's basically hazardous waste to be disposed of (for a fee, of course.)
    When my neighbor was in the same situation last year he calculated the cost of a new tank vs. a natural gas retrofit burner and went with the conversion burner, the old tank went away nearly for free, and got 20-25 square feet of basement floor space back. (That's clearly not an option for everyone.) I'm not sure what the quote for installing a new tank was.
  6. 99k
    Aug 16, 2008
    Five years ago I paid a local oil company to remove my old tank and install a 12 gauge 275 gallon tank for $1,000. I thought that was a steal.
  7. Scuba_Dave
    Scuba_Dave Extreme DIY Homeowner
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    I guess the tank I got for free was a deal :)
  8. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    I dunno- does it leak? ;)
  9. Scuba_Dave
    Jan 5, 2009
    Used to be in IT
    South of Boston, MA
    Nope, barely used - a few years old
  10. Massjim
    Massjim New Member
    Jul 1, 2009
    Estimate
    Well I got the estimate 1600
    pump and filter old tank oil, cut and remove tank, install new 225 slim line tank, new filter and fittings, new overhead copper line.
    Comments??
  11. garyl53
    garyl53 Engineer
    Dec 7, 2006
    Engineer
    Colorado
    Hi,
    10 yrs ago when I lived in MA and had a leak (at the seam) my oil company sent in a crew that cleaned, fiberglassed (the whole bottom), painted the tank, and rechecked for any leaks. It was covered by the service plan. You may want to check into that unless you are looking for increased floor space or relocation of the tank. Maybe you should sign up for a service plan;)
    G
  12. Dana
    Dana In the trades
    Jan 14, 2009
    01609
    Sounds "in the range", not a big gouge.
  13. flamefix
    flamefix New Member
    Sep 4, 2009
    Heating engineer in the UK licensed to fit service
    Exeter, England
    I fit and supply oil tanks in the UK among other things and that price even allowing for USD/GBP conversion is fair in my opinion.
    A buried pipe here would be plastic coated this is particularly so in concrete as the concrete reacts with the copper. You could have the oil line pressure tested for leaks but as you have a quote for a new oil line anyway I'd go for that if I were you.
  14. Ian Gills
    Jul 24, 2007
    USA
    I have never seen oil heating in England. Does it exist?
  15. flamefix
    flamefix New Member
    Sep 4, 2009
    Exeter, England
    Sure it does :) I live in a semi rural area, we have natural gas 80% of the market, electric heating, wood fired and wood pellet heating, oil fired heating and LPG heating plus Solar and Ground source heating.
    You can see what I do on my site www.flamefix.co.uk
    and we have an official registration body OFTEC their site is www.oftec.org
    there is some free information such as this for oil storage for consumers
    http://www.oftec.org/documents/IS_control_of_pollution.pdf
    http://www.oftec.org/documents/Gettoknowyouroiltank.pdf
    I'm not selling anything nor financially benefiting from the above links but if they need to be deleted feel free.
Similar Threads: Tank Replacement
HVAC Heating & Cooling Oil Tank Replacement Part II Should I go Gas? Jul 17, 2009
HVAC Heating & Cooling Oil Tank Replacement Questions Feb 24, 2009
HVAC Heating & Cooling What is the best value 80-100 gallon tank for storage/buffering? Jan 7, 2014
HVAC Heating & Cooling Propane tank, is it ready for work ? Sep 9, 2013
HVAC Heating & Cooling Hydronic air handler: tankless water heater or heat pump Aug 11, 2013
