Oil leak in water heater burner..
Discussion in 'Water Heater Forum, Tanks' started by chigundo, Feb 1, 2012.
  1. chigundo
    chigundo New Member
    Sep 10, 2008
    North Carolina
    My hot water tank's oil burner is leaking oil. It drips a bit when it runs only.. and I believe it's coming from the oil pump. The pump was replaced just over a year ago, and I had it services just in November.. so I think this is just a matter of something not being tightened enough during the last cleaning. Is this something I can attempt myself? I was going to just try and tighten this screw but wanted to check to make sure that wasn't making some sort of adjustment or something.
    [​IMG]
Similar Threads: leak water
Water Heater Forum, Tanks Water Heater Leaking from the bottom. Feb 5, 2017
Water Heater Forum, Tanks Leaking stainless braided water heater hose. Dec 5, 2016
Water Heater Forum, Tanks Hissing and Leak from Cold Water Intake Sep 26, 2016
Water Heater Forum, Tanks New T&P valves on water heater leaking, pressure driven from 65 to 165psi Aug 29, 2016
Water Heater Forum, Tanks What else could it be: indirect hot water heater leaking? Aug 17, 2016
