Oil Fired Furnace
Discussion in 'HVAC Heating & Cooling' started by jrprusak, Oct 29, 2008.
  1. jrprusak
    jrprusak New Member
    Oct 22, 2008
    Anchorage, Alaska
    Service man tuned my garage highboy oil furnace in the garage today and noticed the exchanger is cracked...
    I keep the temperature around 40 degrees, he said it probably cracked from sucking in the colder air...does this sound real?? 20 years old...
    anyways what is a good replacement furnace with a good exchanger?
    It is not connected to any living area, and is just a stand alone unit.
  2. nhmaster
    nhmaster Master Plumber
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    The cold air had nothing to do with it. Don't buy the cheapest and don't buy the most expensive unless you can afford it.
  4. hj
    furnace
    From his explanation, I might want a second opinion, unless you can verify that it is cracked yourself. It is not unheard of for technicians to make a diagnosis, if it is hard for the customer to verify it himself, when there is no real problem, other than that the technician has a car payment coming up and needs the money. I had a similar situation yesterday with regards to a customer's sewer problem. Only part of what he had been told was true.
  5. nhmaster
    Jul 30, 2008
    Tech. Instructor
    S. Maine
    A Rigid mini is a great way to actually see if there is a crack in the exchanger. Another way is to start the furnace and open the inspection door. wait for the blower to come on. If the fire leaps out of the inspection door you have a crack. Soot in the ductwork is also a good indicator. An oxygen reading before blower runs and after blower runs is a great indicator.
  6. jrprusak
    jrprusak New Member
    Oct 22, 2008
    Anchorage, Alaska
    The service guy said the cold air hitting the hot exchanger is why it cracked, not sure about that…I keep the garage around 38-45 degrees during the winter…
    I looked down into the heat exchanger and saw that one wall inside the section the fan blows through is in fact bellied out about 1 inch and has a tight crack about 8†long. I do not have any idea how long it has been like this…
    It still runs fine, and since it is not connected to any living area, it is not a real crises, but I am going to replace…no soot….I’ll do the other test you mentioned waiting for the fan to kik on…..
    I found a Williamson furnace with Beckett burner, life warranty on the heat exchanger..
    The old unit is a Olsen, and may even have a life warranty on the exchanger, I’m looking for the paperwork…
Similar Threads: Fired Furnace
HVAC Heating & Cooling Can a gas-fired furnace be successfully derated? Jan 23, 2014
HVAC Heating & Cooling Stove pipe question for hot air/oil fired furnace Nov 26, 2011
HVAC Heating & Cooling I need help cleaning the hot water coil in my oil fired furnace. Jun 3, 2010
HVAC Heating & Cooling Old Oil-Fired Steam Furnace Aug 24, 2007
HVAC Heating & Cooling Oil Fired Furnace High Pressure Problem May 2, 2007
