Oil Burner Smoking
Discussion in 'HVAC Heating & Cooling' started by brianosaur, Apr 20, 2009.
  1. brianosaur
    brianosaur New Member
    Feb 24, 2009
    Selden, New York
    Just replaced my 275 oil tank last weekend. The old one was leaking and I knew I would replace it this spring when the fuel ran low. Unfortunately I ran out of oil friday and so I replaced the tank. I blew out the feed line with a compressor to make sure no sludge was in it.
    I figured it was a good time for a tune as well so I replaced the nozzle and filter. I removed stack and the top jacket and brushed and vacuumed all the soot. Then I vacuumed the combustion chamber. I also wiped clean the photo sensor.
    Now the furnace is smoking after about a half hour or so. It is coming out of the inspection port.
    Also the control panel it tripping the reset button sporadically. It may run for 15 mins or up to an hour of cycle time.
    I didnt adjust anything so why would this 'just start' to occur? Does it need more air?
Similar Threads: Burner Smoking
HVAC Heating & Cooling Seems my new millvolt gas valve turns off PILOT and MAIN BURNERS? Oct 12, 2015
HVAC Heating & Cooling Carlin or Becket tBurner Jun 20, 2014
HVAC Heating & Cooling How to choose oil burner relay switch? Jan 15, 2014
HVAC Heating & Cooling Ducane burner, perhaps pilot, won't light Jan 3, 2014
HVAC Heating & Cooling Unbalanced oil supplyline due to de-aerator? Air causing one burner to cut out. Dec 26, 2013
