Tacman7
Hi,
New to the forum and in need of some advice.
We have a submersible pump that fills a 1000 gal galv tank, then a booster pump and one pressure tank.
My booster pump went out and I replaced the 1hp pump with a 1.5hp pump (because of impending upgrade) but forgot about a check valve. So I put a plastic one I got at home depot right before the pump like the old one was installed.
Also put in a new squareD M4 control on the pump.
The problem is that it doesn't come on, it tries to then stops then tries, so it's just click click click, off on off on, like tearing up the pump.
I tried moving the check valve to the other side of the pump, moving where I sense the pressure for the pump, and various other things.
I'm a do it yourselfer but I'm out of my league here I'm afraid.
The tank has a 1 1/4" outlet where I put in a new ball valve, but the pump has 1 1/2" inlet and outlet, so I went to 1 1/2" right off the ball valve. I thought bigger pipe more flow etc.
But maybe the check valve is too hard to open and I'm getting the cycling etc.
Appreciate any help, Thanks
P.S. My galvanized tank has rust spots all over it and I'm thinking of buying a 1500gal plastic tank and relocating the installation a little more out of sight, but that's for another day.
