Oh where, oh where does that circuit go?
Discussion in 'Electrical Forum discussion & Blog' started by bmaker, Jan 16, 2013.
  1. bmaker
    bmaker New Member
    Dec 27, 2011
    Doing a bit of remodeling on my daughter's kitchen. They have a switch on the wall that doesn't seem to control anything, although I can tell it is wired up to a hot circuit. I've checked all the outlets and lights in the immediate vicinity, even the garage and outdoors. Is there an electrician's trick to chasing down a circuit short of tearing out the wall and physically following the wire?
  2. jimbo
    jimbo Plumber
    San Diego, CA
    Look for an outlet in the room where ONE of the plugs is controlled by the switch. This is a code requirement if there is not a ceiling light in the room. POSSIBLE PROBLEM: l over the years, if that particular outlet was replaced, someone may have failed to wire it back so it is controlled by the switch.
  4. LLigetfa
    Feb 6, 2011
    Information Technology
    NW Ontario, Canada
    I have a circuit tracer that can follow wires inside walls, even inside EMT but it is not something the average DIYer would have.
    You might be able to generate a noise that an AM radio can pick up and use the radio to follow the wire.
  5. jadnashua
    In a kitchen, that switch could control something like a garbage disposal. It might go to an outlet under the sink, but it could go lots of places.
  6. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    Is it in a ganged box with other switches? If so, what are the other switches for? A ceiling fan may have been wired with an extra conductor for a light but the light never broken out to its own switch. See if the wire in the box is 3 conductor and if so where the other conductor goes. I wire my ceiling fans with 3 conductor JIC I decide to have a lamp as well. I hate when they are wired common with the fan and need to use the pull chain.
  7. ActionDave
    ActionDave Electrician
    Feb 4, 2009
    Electrician
    Colorado
    Kill the power to it and go home....wait for the call, "My xxxx is not working."
  8. bmaker
    bmaker New Member
    Dec 27, 2011
    I checked some of the duplex outlets but maybe not all. Will try that.
  9. bmaker
    bmaker New Member
    Dec 27, 2011
    There is a ceiling light but not a fan. Perhaps there used to be. Will check out this option.
  10. bmaker
    bmaker New Member
    Dec 27, 2011
    No garbage disposal but there was an in-counter blender thingy that we got rid of. I checked that circuit but alas it was fed from a different breaker.
  11. bmaker
    bmaker New Member
    Dec 27, 2011
    Hah! Best suggestion yet. I'll do that after trying the other ones above!
  12. teamo
    teamo Member
    Jun 26, 2005
    Massachusetts
    Dishwasher disconnect?
  13. hj
    quote; No garbage disposal
    BUT, could there have been a circuit for one when the house was built? Unless it was in the 40s, it would have be de rigueur to install one.
  14. bmaker
    bmaker New Member
    Dec 27, 2011
    Probably not, since the switch is over by the back door, several feet from the sink. The more I think about this, the more I'm thinking it must be either a switched outlet or a circuit in the garage. Will check next time I'm over there.
  15. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    When I wired my home, I put two switches in the mud room for future consideration. The wires simply terminate down in the crawlspace for now. Eventually they will control outdoor lights.
  16. big2bird
    big2bird IBEW Electrician
    Sep 29, 2012
    IBEW Electrician
    Anaheim, Ca.
    I used to install a switch by the back door for the garage door opener. "Vacation switch."
  17. hj
    Have you actually looked at the switch to be sure it is NOT a three way switch for something? Switches by back doors are usually 3 way or they control something outside the house.
  18. LLigetfa
    Feb 6, 2011
    NW Ontario, Canada
    I put several outlets under the eaves for roof de-icing cables that are wired to switches. Those switches however I put in my wiring closet as I didn't want someone to turn it on by mistake and run up my electric bill.
Similar Threads: where where
Electrical Forum discussion & Blog Is 97 volt AC a possiblity in a wire to nowhere? Nov 16, 2016
Electrical Forum discussion & Blog Where in the World is Mike ? Jul 14, 2011
Electrical Forum discussion & Blog 220 V well timer. Where can I find one? Jan 26, 2010
Electrical Forum discussion & Blog Thermostat - Where to insert wires? Dec 23, 2009
Electrical Forum discussion & Blog Where should doorbell transformers be mounted Nov 16, 2009
