Vince DR
hello.
I have three Toto CST854 elongated toilets where the flappers are at the point where they are hanging on by a thread. Because the toilets were there prior when we moved it I am unsure what the part to replace the flapper is. I managed to find the following:
http://www.korky.com/flappers/genuine-toto-3-universal-flapper
The flapper should be relatively easy to replace as long as I follow the instructions right? What I am finding now is that water is seeping between the flapper and 3" hole very slowly to the point where the water level will eventually go below the fill line and the tank will add more water.
Is this the case where I need to find the exact OEM part?
**some troubleshooting
I've allowed the tank to fill and closed the water supply at the shutoff valve. I want to determine if it is the flapper or the flush valve.
Emptying the tank water up to the level where the flapper and the flush valve meet and I let it sit overnight the water level did not drop past the top of the flush valve, so the issue is the flapper right?
Thank you in advance.
