Odd water supply location--what toilet will work?
Discussion in 'Toilet Forum discussions' started by Judie, Mar 21, 2006.
  1. Judie
    Judie New Member
    Mar 21, 2006
    I'd planned on replacing an old toilet with a Toto Drake, but the spec sheet seems to indicate that the toilet sits
    very close to the wall. The water supply comes in directly behind my toilet--no offset--and I'd rather not hire a plumber to move it. (There's an air vent on one side of the water supply and heaven knows what on the other side--the other toilets in the house have the water supply offset, so I suspect there could be a reason this one is the way it is.)
    Does anyone know whether I'm reading the spec sheet correctly? Or have a Drake installed that they can look at? I'd need at least a 3.5 inch clearance between the wall and the toilet. (The water supply is 7" from the floor, if that helps, and the toilet flange is the standard 12" from the wall.) Obviously I could go to the plumbing supply store and look, but it's a long drive away so am hoping somebody can help.
    If Totos are out, can anyone recommend a good alternative that might work?
    Thanks,
    Judie
  2. jadnashua
    It doesn't look like the Drake would work unless you put an elbow on the supply line and ran it out to where it would clear.
  4. Spokaneman
    Spokaneman New Member
    Dec 14, 2005
    Spokane WA
    I would think that while you have the toilet out, soldering an elbow to move the valve to an offset position would be time (and money if you hire it done) well spent, in case you need to get to the valve in a hurry. Soldering a fitting is quite easy or even use a compression fitting if necessary (that makes the pros cringe).
    Since the supply line is behind the toilet, presumably out of sight, if you bugger up the wall a bit, it should be not a big deal.
Similar Threads: water supply
Toilet Forum discussions Toilet water supply has been off a while...try to turn back on now and get a horrible loud noise... Jan 18, 2017
Toilet Forum discussions Any creative solutions for top of tank rear inlet water supply? Nov 16, 2016
Toilet Forum discussions Is water supply from the floor a bad idea? May 17, 2016
Toilet Forum discussions Toto Unifit & Water Supply Location Jan 12, 2016
Toilet Forum discussions Floor Water Supply - What Toilet Options Are Best? Nov 30, 2015
