Odd vibration from well pipe with power off
Anthony V Jr
Rhode Island
Hello all. Is there any reason why the pipe going into the house from a submersible well pump would be vibrating slightly when the power is off? Vibrating enough that you can hear the humming of the vibration in the tank?
I shut off the well pump breaker to diagnose something (and even disconnected the wires in the control switch to make doubly sure), checking it with a voltmeter before and after. It feels like a vibration that would be coming from a running well pump transferred over distance, but there is no way I can see that there should be power to it. As far as I can tell, there are no other power supplies. Any way it coulld be,Any help or suggestions would be greatly appreciated.
Anthony V Jr
Rhode Island
Does the pressure decrease while the pump is off and no one using water? You could have a leak or a bad check valve spewing water that could make noise.
Thanks for the suggestion. I was hoping to have an answer to your question tonight because I had to replace the pressure gauge (and did the check valve near the tank since it was inexpensive), but I decided to check the integrity of the hoses/elbows that go from the well line to the valve and moving them apparently broke a seal that had formed over the years so when I turned back on the pump, water started spurting out of two of the connections and the clamps would not seal it no matter how tight I got them. Now I have to replace those before doing anything else.
