Odd sized sink basket
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bugleg, Oct 12, 2009.
  1. bugleg
    bugleg New Member
    Oct 12, 2009
    nyc
    I have an old slate sink (maybe from lab?) that has a odd sized drain basket--the ID is 2 3/8" and the OD of the recess is 3 3/8".
    I've stopped by a few supply houses looking for something but struck out. I don't need anything fancy--just need to connect the sink to a 1 1/4" tailpiece.
    Any ideas?
  2. jadnashua
    I'd be surprised if it was slate, probably soapstone, but that doesn't help. Check out kitchen sink fittings, they tend to be larger - you may find one of those that would work.
  4. bugleg
    bugleg New Member
    Oct 12, 2009
    nyc
    Rereading my message it is worded poorly--I am looking for the basket itself, as my sink doesn't have one.
  5. hj
    drain
    If it was from a lab, then the drain fitting is probably some composite material and could be a 2" pipe size. Most of those did not have "baskets" in them. When they had to retain water, they used a standpipe in the drain fitting to provide for overflow protection. If you are looking for the entire drain fitting, not just the "basket" then you may have to look in the chemical waster section of specialty catalogs. The one you find will probably be a 2" thread so you will have to reduce it down to your pipe size.
Similar Threads: sized sink
Plumbing Forum, Professional & DIY Advice Strange oversized kitchen sink drain basket Aug 9, 2012
Plumbing Forum, Professional & DIY Advice Source for old oversized sink drain strainer assembly? Jun 12, 2009
Plumbing Forum, Professional & DIY Advice Oversized gas exhaust flue for boiler and water heater Wednesday at 10:14 AM
Plumbing Forum, Professional & DIY Advice Question about odd sized crimp ring. Oct 7, 2014
Plumbing Forum, Professional & DIY Advice Contractor mistakes? Wet vent, downsized line? Jun 7, 2014
