Odd size steel pipe nipples
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by ej, Nov 11, 2004.
  1. ej
    ej New Member
    Nov 11, 2004
    California
    Hello-
    I'm putting in a tub faucet and need a 3 1/4" nipple in order to have <1/8" gap to caulk. Using the standard 3 1/2" that I can get at home depot, I end up with a 3/8 gap which seems a bit much, and 3" is too short.
    The Home depot guy said to mate up smalller nipples with a coupling; is that the typical solution for pro's? I'm nervous enough about having two hidden joints in the wall that could leak, much less four. It also seems like it'll also get squirrely trying to get the faucet to end up in the down facing position when they're all tightened up.
    How do you folks do it, or am I making too much of this?
    thanks-
    Ed
  2. LonnythePlumber
    LonnythePlumber Plumber, Contractor, Attorney
    Sep 6, 2004
    Wichita, Kansas
    Slip Spout
    You are correct in wanting to get a good seal at the spout to wall connection. You could install a piece of copper and use a slip on spout. Or you could get a spout that has it's pipe connection at the nose (outlet) instead of at the wall. I have used the coupling approach.
  4. ej
    ej New Member
    Nov 11, 2004
    California
    Thanks, Lonnie. The spout is part of the fixture package, and the wife really likes it, so changing the spout is out.
    You mentioned copper which got me thinking.... Can I just make it out of copper and sweat two threaded ends to the correct length of tubing? or do I risk damage when trying to tighten it up? That could make it very easy come to think of it.
    -Ed
  5. jimbo
    jimbo Plumber
    1. You can make up a nipple from a piece of copper and two male adapters; it is simewhat fragile. Especially when you need to remove it, the copper might twist.
    2. A big plumbing supply house may stock nipples in 1/4" increments; also the supply house or a large contractor probably has a nipple attachment for their threading machine and can make any length.
  6. LonnythePlumber
    Sep 6, 2004
    Wichita, Kansas
    1/4" Nipples
    Jim do you know that for sure that some supply houses have 1/4" increments?
Similar Threads: size steel
Plumbing Forum, Professional & DIY Advice Correct gas regulator size and specs Saturday at 3:51 AM
Plumbing Forum, Professional & DIY Advice Vent size? Tuesday at 8:49 PM
Plumbing Forum, Professional & DIY Advice Minimum toilet vent size? Dec 11, 2016
Plumbing Forum, Professional & DIY Advice Sanity check on pipe sizes for new construction Nov 26, 2016
Plumbing Forum, Professional & DIY Advice New construction main waterline size 900' from meter Oct 3, 2016
