- Messages
- 33,603
- Reaction score
- 1,042
- Points
- 113
- Location
- Cave Creek, Arizona
- Website
- www.terrylove.com
dope
I see your 20 years and raise you by 40. And in those 60 years, I have NEVER used "goop" on slip joint connections, (in fact in the old days, dope would rot the rubber gaskets and CAUSE leaks). I also do not use dope and teflon tape. In fact I ONLY use teflon tape on male plastic threads, never metal ones. I have not had the problems you cite with B-W heater threads, do not use putty under the gasket on lavatories, and DO NOT get callbacks regardless of how far away the job is. You and I might have some discussions about gooping the joints if I worked for you, but then everywhere I have worked, even as an apprentice, I have been the superintendent telling the journeymen how to do it.
