Oatey brass no-caulk shower drain
Discussion in 'Shower & Bathtub Forum & Blog' started by hifibuf, Feb 5, 2007.
  1. hifibuf
    hifibuf New Member
    Feb 5, 2007
    New Jersey
    I'll be using an Oatey brass no-caulk shower drain in my bathroom project. I test fit the drain on a piece of 2" PVC to see how well it grips the pipe. I noticed when tightening the caulk ring nut that it starts to bind against the rubber caulking ring and makes it difficult to get it tight enough. Should I apply a lubricant between the no-caulk ring and the ring nut? If so, what should I use? Soap? Last question - how tight is tight enough? If it leaks it ruins my first floor ceiling.
    Thanks,
    Richard
    [​IMG]
  2. lkrides
    lkrides New Member
    Dec 14, 2006
    Maryland
    I'm far from an expert, so I can't answer your question. But I am past the drain stage of my bathroom project. So I ask you a question, why not just use a pvc drain? Seems to me you would have less worries about leaks. I was amazed at how strong the chemicals bond the pvc. They sell a complete kit at the retailers.
  4. hifibuf
    hifibuf New Member
    Feb 5, 2007
    New Jersey
    Access.
    1) It would be immpossible to get the shower pan in place before the glue dries.
    2) No way to back up the pipe/trap so that sufficient force could be applied to properly seat the pipe into the drain fitting - without eliminating the little bit of "adjustment" movement that PVC gives.
    3) It's too permanent. If repairs are ever needed in the future the whole mess would need to be cut apart.
    4) Brass looks much better than white plastic on my Biscuit colored floor.
    Other than that, I can't think of a single reason. :D
  5. lkrides
    lkrides New Member
    Dec 14, 2006
    Maryland
    That's a lot of good reasons.
    I have access below my tub. I used PVC and a piece of Fernco coupling to increase the adjustability and make it easier to disassemble in the future. The visible portion of the drain is available in chrome, brass, brush.
  6. jrseaberg
    jrseaberg New Member
    Dec 24, 2006
    manage a small business facility
    central IL
    Answer for Oatey drain question?
    "bump" for Richard's question....:p
    Should I use any type of "lubricant" when tightening down the internal nut on the rubber "donut" or ring in the Oatey no caulk drain?
    (I did make sure to tighten the nut on the bottom and use thread sealer to help make sure it doesn't work loose.)
    Jim
Similar Threads: Oatey brass
Shower & Bathtub Forum & Blog Trying to remove Oatey Casper's SBCCI ES drain cover Sep 25, 2015
Shower & Bathtub Forum & Blog Drain Pipe Question for Oatey No-Calk Drain - Height, Stability, etc. Jan 30, 2013
Shower & Bathtub Forum & Blog Cultured Marble shower base and Oatey "No-Calk" Oct 7, 2012
Shower & Bathtub Forum & Blog Oatey "no-caulk" drain leaking in shower w/ acrylic pan Feb 11, 2012
Shower & Bathtub Forum & Blog Installing LASCO shower stall with Oatey No-Calk drain Jan 31, 2012
