Oatey 4" x 4" saddle tee
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by Lakee911, Oct 14, 2005.
  1. Lakee911
    Lakee911 I&C Engineer (mostly WWTP)
    Aug 23, 2005
    Columbus, OH
    I would like to relocate my cleanout to place a utility sink. Because the sink will block the old one, can I install a 4"x4" Oatay (Model No 43795) Saddle Tee a couple feet of higher than the old wye? It would be too hardto insert a real wye or tee. Do saddle wyes exist? Where are those to be found?
    I think this would be ok, but I'm not sure. Most of my house is cast iron except for a short portion in the basement that I can easily tap into.
    What's the best way to cut this 4" hole? I was thinking of using a large spade bit and then a sawzall. I'd maybe drive a screw in the "plug" that will come out, tied to a string for retreival purpses if needed. :rolleyes:
    Thanks,
    Jason
    (Yes, I have lots of projects going on, hands in a little bit of everything).
  2. Terry Love
    Terry Love Plumber
    Aug 17, 2004
    Bothell, WA
    You would want to use a hole saw.
    Would this be for relocating the cleanout?
  4. finnegan
    finnegan New Member
    Aug 16, 2005
    CT
    Most folks don't think much of saddle tees, but assuming yours will be used as a cleanout, you should be ok. Waste will likely never be as high as the tapped area of the pipe, so there is not much risk of leaking. Though, you may never need the cleanout so you you could always hold off on the saddle tee until you have a problem and install it if you ever need access to the pipe.
  5. Lakee911
    Aug 23, 2005
    Columbus, OH
    Yes. I don't have a hole saw that big. Might have to invest in a 4incher.
    I guess leaking could be a concern. Is there anything I can do to improve my chances of a good wield with the solvent? Primer, lots of glue, stick it and bolt it all lickity split? (BTW, house has needed yearly cleaning of tree roots since '68! Trying to build my own sewer cam, see other thread, to investigate.)
    Anyone know of a saddle wye?
    Thx,
    Jason
Similar Threads: Oatey saddle
Plumbing Forum, Professional & DIY Advice Oatey Caspers SBCCIES Shower Drain Removal Nov 11, 2016
Plumbing Forum, Professional & DIY Advice Oatey gripper down the drain Sep 24, 2016
Plumbing Forum, Professional & DIY Advice Oatey 95 flux residue still in pipe Aug 5, 2016
Plumbing Forum, Professional & DIY Advice Oatey No Caulk Brass Shower Drain Jan 29, 2016
Plumbing Forum, Professional & DIY Advice Oatey Plumbing Flange Question Jan 7, 2016
