Number of fixtures per line?
Discussion in 'Plumbing Forum, Professional & DIY Advice' started by bmod, Sep 18, 2006.
  1. bmod
    bmod New Member
    Sep 18, 2006
    Hi,
    Situation:
    New house with pex plumbing. 1/2" lines from 3/4" hot & cold manifolds to each fixture in the main level bathroom. Each fixture has its own 1/2" pex line to the master manifolds.
    Question:
    I'm installing a bathroom in the basement that is directly under the main level. Can I tap into each 1/2" pex line for the basement fixtures or do I have install additional hot & cold manifolds and then run individual 1/2" lines back to each fixture just like the upstairs bathroom. For example, tap into upstairs tiolet for basement tiolet. Upstair sink to downstairs sink etc
    Thanks in advance,
    Dave
  2. Cass
    Cass Plumber
    Nov 12, 2005
    If you tap into the 1/2" pex and someone in each bathroom trys to use water the flow will not be good. If it were me I would add a take off to the manifold if there isn't one that can be used or add a T some where on a 3/4" line near / B4 the manifold.
Similar Threads: Number fixtures
Plumbing Forum, Professional & DIY Advice Maximum number of fixtures Nov 9, 2006
Plumbing Forum, Professional & DIY Advice Model Numbers Differences at Home Depot Nov 23, 2014
Plumbing Forum, Professional & DIY Advice Toto Carlyle MS874114SG Replacement Part Numbers for all internal guts Jun 4, 2014
Plumbing Forum, Professional & DIY Advice Limit on number of turns in a vent? May 10, 2014
Plumbing Forum, Professional & DIY Advice taco circulator with different model number Feb 3, 2014
